So here's the deal, I got a Steeda shifter a while ago... when its bolted all the way down its impossible to shift, the only way to make it possible to shift is to have it bolted down loosely.
Obviously this is a problem but I pushed it to the side with my busy college life, now the transmission makes a light noise when I'm in neutral (like a grinding or better explained sounds like something loose is running around in the trans), I don't believe it happens when I'm in gear. I think this is because of low transmission fluid from the shifter not being all the way on.
So my questions are
1)whats wrong with my shifter? do i need to tighten all the bolts to a cretin amount? is it just messed up... I got it on e-bay but shifts fine when not bolted all the way down
2)whats wrong with the tranny? I'm hoping its just low fluid and hope someone will confirm that.
THANKS GUYS
-------02 gt, 5spd
So my questions are
THANKS GUYS
-------02 gt, 5spd
