  • 1994 - 1995 Specific Tech
Steeda tri ax problem
  • Thread starter Thread starter drewzx3
  • Start date Start date Apr 12, 2007
D
drewzx3
411
Louisiana
Apr 12, 2007
  • Apr 12, 2007
I got my used tri ax in today and when I installed it the ball part that goes into the shifter mechanism will slip out of it with the shifter all the way bolted down but the stock shifter does not do this. I made sure it went into the mechanism and it will stay in there for a minute then it will just pop out and you can move the shifter all around with out it going to any gear. Anyone have any ideas or did I just get the shaft?
GTA_V6_Mustang
1,326
Miami, FL
Apr 12, 2007
  • Apr 12, 2007
I am sure others here can help you more but if you can get up some pics it may be easier to help you out.
4G-KDMP
935
CA
Apr 12, 2007
  • Apr 12, 2007
do you still have the plastic bushing part in the trans so that the ball stays tight in the trans?
ProKiller
3,064
15
78
PA
Apr 13, 2007
  • Apr 13, 2007
D
drewzx3
411
Louisiana
Apr 13, 2007
  • Apr 13, 2007
Yep its still in there.
4G-KDMP
935
CA
Apr 13, 2007
  • Apr 13, 2007
steeda makes about 5 different tri-ax shifter to fit different years and trans do you know {since you said you got it used} that what you have works correctly in your trans?
this might be helpful
http://www.steeda.com/products/drivetrain_shifters.php
D
drewzx3
411
Louisiana
Apr 13, 2007
  • Apr 13, 2007
The guy at steeda says he thinks that its for a 3650. I cant find anyone that I know with that transmission though to try it.
HISSIN50
34
129
Apr 13, 2007
  • Apr 13, 2007
I dont know the differences in the shifter models myself. Doesnt a 3650 come in the last batch of GT's (01 or 02+)? If so, maybe ask in that sub-forum for the guys to measure their shifter shaft length (or whatever it is that might be different) so you can compare yours to theirs.
:OT: Guero, I opened the door for you with all this talk of shafts and comparing lengths. Let's have it.
T
tjh566
608
Northern Va
Apr 13, 2007
  • Apr 13, 2007
Not sure on this, someone chime in here, the bottom part of the stocker and the tri-ax should be that same shouldnt it, the short throw comes from the shorter shifter handle and a different mechicanical advantage. I would think in order for it to work the bottoms would have to be the same. Agian someone come in on this. Compare your shifters and see what it looks like??
True 5.0
237
Southeastern Wisconsin
Apr 13, 2007
#10
  • Apr 13, 2007
  • #10
Yes. the portion below the mounting plates need to be the same between the two.
B&m hammer shifter c4 question
  • 387lx
  • Mar 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 19, 2026
387lx
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
9
1994 Mustang GT 5.0 L Convertible
  • 94ns95
  • Jun 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 19, 2026
94ns95
9
I
1994 Cobra - Fuel Pressure Drops Revving at Idle
  • IconicSilverGT500
  • Apr 11, 2026
1994 - 1995 Specific Tech Apr 24, 2026
Mcmahst
P
2002 T5 transmission vibration issue
  • puffoo
  • Feb 22, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Feb 22, 2026
puffoo
P
