  • SN95 4.6L Mustang Tech
Steeda U/D Pullies
  • Thread starter Thread starter NewMStang
  • Start date Start date Feb 4, 2009
First Prev 2 of 2
G
GettinThere
553
Central Texas
Feb 6, 2009
#21
  • Feb 6, 2009
  • #21
NewMStang said:
So with that said, you still felt some gains, correct? I just don't want to dish out $200 and feel no gains b/c i decided against installing the alternator pulley.
I didn't feel any gains, but my sotp meter has never worked well. The gains are there, it's just difficult, if not impossible, to feel the difference. I can barely tell the difference with 4.10 gears and a 100 shot of N2O.
Using or not using the provided Steeda alternator pulley makes practically no difference.
LastCallRacing
Premium Sponsor
Dec 4, 2008
172
San Diego, CA
Feb 6, 2009
#22
  • Feb 6, 2009
  • #22
If you can feel 5hp with your pants, you've got a very finely calibrated crotch. I'm not trying to dog the pullies, or those who have installed them, but for the money, you might see better gains putting it towards a tune where you should make more power you can feel.
-Patrick
MaxedGT
304
Surrey BC Canada
Feb 7, 2009
#23
  • Feb 7, 2009
  • #23
I've got the steeda underdrives and I love em. No one bolt on makes a huge seat of the pants difference, it's the right combo of mods that work together. I think they're worth it for the power improvement with the a/c on alone. That Was the biggest difference I noticed. At idle the lights dim a bit and the wipers slow down, but unless you spend a huge amount of time at idle in traffic in the rain at night, no problem. If you're powering some high powered amps then I wouldn't recommend them. I'd give em an 8 outa 10.
M
mutabi
#24
  • Feb 7, 2009
  • #24
I also have the steeda UD pullies on my 02. The alternator pulley is an overdrive pulley (its larger). I didnt bother putting that pulley on. still able to keep the stock belt on there no problem. Have been running like that for a lil over a year with no problems.
Easy enough upgrade. Worth it, unless u plan on adding a supercharger.
Silverstang02GT
60
Ft. Myers FL
Feb 7, 2009
#25
  • Feb 7, 2009
  • #25
I have had Steeda pulleys on my car for over 90,000 mile with no problems. as far as the alternator goes if you use to small of a pulley it could cause problems.
An alternator needs 1800-2000 at idle to make power and will make maximum output at 6000 rpm, and will start to fail at 16,000 RPM.
To calculate the alternator shaft speed, which should be no more than 16,000 RPM do the following:
Alternator pulley size (ie 2.5")
Crankshaft Pulley Size (ie 5")
Ratio is 2:1 (5 / 2.5 = 2)
Max engine Speed = 5800 RPM
Multiply Max RPM x Ratio (5800 x 2) = 11,600 shaft RPM Max
Idle RPM = 1000
Multiply Idle RPM x Ratio (1000 x 2) = 2000 shaft RPM @ Idle
I would think Steeda took this in account when they designed there under drive pulleys
Tazzy
21
PA
Feb 8, 2009
#26
  • Feb 8, 2009
  • #26
I bought a used set of steeda underdrive pulleys at a good price but they didn't come with the installer bolt. Does anyone have a bolt for sale or know the exact length and thread size of the installer bolt? It's for an 04 GT.
trinity_gt
3,125
81
99
Canada
Feb 8, 2009
#27
  • Feb 8, 2009
  • #27
You'll want either an ARP part:
ARP 156-2501 - ARP Balancer Bolt Kits - summitracing.com
or to go to the dealer and get a new TTY unit. The TTY parts are one-time use only. The ARP bolt can be re-used many times.
Tazzy
21
PA
Feb 8, 2009
#28
  • Feb 8, 2009
  • #28
Is this the bolt to start the pulley onto the motor before switching to the original sizebolt?
Tazzy
21
PA
Feb 9, 2009
#29
  • Feb 9, 2009
  • #29
Anyone have an actual steeda UD pulley installer bolt and can measure the length and thread size? Or have one they are not using and can lend me or sell me?
First Prev 2 of 2
96-04 Steeda UDP using ONLY Water pump & crank pulley?
  • Stangg338
  • Oct 22, 2021
1996 - 2004 SN95 Mustang -General/Talk- Oct 22, 2021
Stangg338
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
  • 1994 - 1995 Specific Tech
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
V
Suspension New Power Steering Rack Options - 1990 GT
  • Vix
  • Sep 2, 2020
2K
Fox 5.0 Mustang Tech Sep 2, 2020
Vix
V
R
Fox Closed PCV System, Dual Valve Catch Can
  • RTW0223
  • Dec 6, 2019
15K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 30, 2021
jay98
M
I really wasn't expecting this....... First time Mustang owner.......
  • Mikedd969
  • Nov 27, 2019
3K
1996 - 2004 SN95 Mustang -General/Talk- Nov 28, 2019
Mikedd969
M
