steering column
  • Thread starter Thread starter kjak7830
  • Start date Start date Jun 9, 2007
K
kjak7830
  • Jun 9, 2007
How hard is it to change the steering column on an 86 mustang? My car got broken into the other night and the messed it up bad. Also what can you tell me about changing the fuel pump? Any help is greatly appreciated.
GSXRMIXXER
97
  • Jun 9, 2007
column + fuel pump = easy swaps
Hickfied
413
Morganton, NC
Jun 9, 2007
  • Jun 9, 2007
If I remember correctly, two bolts and four nuts, or just 6 nuts and then undo the steering shaft from the rack along with a few wiring connections, and it''s out.
To replace the fuel pump:
take the two tank straps off (two 14mm bolts if I remember correctly) making sure to have a jack under the tank
unbolt the filler tube from the tank (one 10mm bolt) and pull it from the tank, making sure not to rip the seal ($30 from 50resto, $50 from the dealership)
Lower the tank some more, and disconnect both wiring harnesses, and both fuel lines, along with the evap vacumm line.
Safest way to take the locking ring off is with a brass punch and a hammer, but I just used a screwdriver and a hammer to turn it off.
Pull the pump out, it may be rather had to get it to come out.
Undo both wires, take the sock filter off, and take the pump out, then replace with the new one, with a new filter sock, and hook the wires back up.
Getting it back into the tank, the right way, was the hardest part for me, it actually took longer for me to do that, than the rest of the process.
Reinstall everything you unhooked, in the reverse order. If the little clips on the fuel lines broke, a couple zip ties on both work great... And if you ripped the filler tube seal (don't worry, you wont be alone on that one) and you can't get a new one fast, RTV works wonders.
Drivetrain Wilwood Clutch and Brake Pedal Combo Installation - Help
  • 427stang
  • Jul 8, 2026
Fox 5.0 Mustang Tech Jul 8, 2026
427stang
N
Engine 86 GT no start/stall
  • nweber
  • Jul 28, 2026
Fox 5.0 Mustang Tech Jul 29, 2026
AeroCoupe
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
T
Aftermarket Steering Column
  • Tas_Jak
  • Jul 18, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 18, 2025
Tas_Jak
T
