Steering Column
  • Thread starter Thread starter snoball_kyzer
  • Start date Start date May 26, 2010
snoball_kyzer
11
  • May 26, 2010
My steering column is so bad you have to pull down on the steering wheel before the car will start. How do I fix this?
Vinnietbird
584
  • May 26, 2010
Is the column loose? Have you checked the ignition switch?
pedro
432
May 26, 2010
  • May 26, 2010
Sounds like a f'ed up ignition switch.
snoball_kyzer
11
  • May 26, 2010
The whole steering column moves. It has a new ignition switch. I couldnt find any replacement parts for it.
Vinnietbird
584
  • May 26, 2010
More questions.....The WHOLE column moves or just the steering wheel/tilt part? Is it bolted down good under the dash.
snoball_kyzer
11
  • May 26, 2010
Just the tilt part. Once you pull down its like the ignition makes connection and it will start.
K
Kerpal
400
  • May 27, 2010
Sounds like you need to replace the entire column...
It may be able to be rebuilt somehow, but it's easier just to get another one that's in better shape. The columns wear out over time, I had to replace one in my old ex-police Crown Vic. Matter of fact I think the one in my Mustang may be starting to go as well...
2000xp8
SN Certified Technician
Aug 8, 2003
8,058
1,643
194
NJ
May 27, 2010
  • May 27, 2010
columns are only like 50 bucks at the junkyard, and aren't very hard to replace.
slow84lx
clean it good before insertion
Jul 3, 2005
372
180
63
Dallas, TX
May 29, 2010
  • May 29, 2010
Here is some reading for you:
Mustang Central.net Steering Column Fix
snoball_kyzer
11
#10
  • May 30, 2010
  • #10
thanks everybody i appreciate it.
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
Drivetrain Wilwood Clutch and Brake Pedal Combo Installation - Help
  • 427stang
  • Jul 8, 2026
Fox 5.0 Mustang Tech Jul 8, 2026
427stang
L
69 tilt steering column endplay
  • loubischoff
  • Feb 10, 2026
1965 - 1973 Classic Mustangs -General/Talk- Feb 10, 2026
loubischoff
L
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
A
90 Fox Manuel steering
  • adimice
  • Apr 2, 2026
Fox 5.0 Mustang Tech Apr 2, 2026
Bullitt347
