Steering issues....need recommendation
  • Thread starter Thread starter dkeiser1989
  • Start date Start date Dec 2, 2006
D
dkeiser1989
15
  • Dec 2, 2006
my '89 sat for about three years, and I recently got her going again. Before I parked it, I had replaced the steering rack about two months prior. now that I've got it going again, I am having trouble with the steering. it feels like I'm constantly fighting to keep the car straight, which is the same way it felt before I replaced the rack. it's been aligned. are ford replacement racks known for going bad this quickly? could sitting for so long have damaged it? I was thinking of replacing the power rack with a manual rack, and was wondering what those are like to live with. Thanks.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Dec 2, 2006
  • Dec 2, 2006
How much slack are in the tie rod joints and universal & flex joint steering shaft couplers?
The universal and flex joint steering shaft couplers can be inspected with the car parked on the ground. With the engine off, have a helper rock the steering wheel back and forth while you inspect the universal and flex joint steering shaft couplers for excessive slack. You'll need a sharp eye and a strong light to do a good job.
Support the car on jackstands with the jackstands placed as close to the wheel as possible. With the steering locked, have a helper try to move each front wheel just like it would move if you turned the steering wheel. While they are rocking the wheels, you are under the car watching for slack in the tie rods.
bubba-dough
1,044
Indiana
Dec 2, 2006
  • Dec 2, 2006
Check your rack bushings as well. Those rubber p.os.'s could be the culprit as well.
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
A
Electrical electric mirror switch issue...
  • alchemist1
  • Apr 18, 2026
Fox 5.0 Mustang Tech Apr 19, 2026
2000xp8
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
P
Is it normal for all of this to go wrong or did I get played when I bought this ONLY A MONTH AGO.
  • ponygal02
  • Nov 14, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 14, 2025
