Steering question??
83rs5.0
I have a 83 Capri RS, have rebuilt front end with later HD Ford a-arms bushings etc., added bigger rotors and calipers etc. Replaced power rack 2 times now due to thinking it had play in it but now begin to think front end alignment may be at fault?? It is lowered in front 1-1.25" as it rode way high in front. put Ford caster/camber plates on and had aligned. Now back to play in steering-it seems like it falls into corners at a certain point, is very sensitive on highway and is the easiest steering Fox body I have ever had or driven (have 6). Any one with experience here please help!
Rag joint checked and seems to be fine. Yes there are different ratio racks you are correct. It corners great except at a certain point you sort of have to hold it back-it wants to go deeper into the turn. It reminds me of a cat trying to walk on water. I upgraded to 93 GT or newer parts. It steers so easy, not like any of our other Foxs, also my 93GT when you turn and release the wheel it returns to center (straight) this one does not.
My Capri does that too. I only upgraded the spindles to 92 year models. I figure that the ones with the larger brakes have rack limiters. I have not yet installed them but I will when I go to my set of 96 spindles.
Allen
