steering shaft & headers??????
  • Thread starter Thread starter 1980coupe
  • Start date Start date Oct 18, 2007
1980coupe
CHICAGO
Oct 18, 2007
  • Oct 18, 2007
been feeling this rubb through the steering wheel and looked under the hood I noticed my shaft is rubbing just a little on my headers! the front frame,suspention and motor is out of my 84 gt and put it in my 1980 coupe that was a straight six! my gt never had this problem! is there a slight difference some where??
i hear to bend the header a bit but i would hate to restrict the header! is there another way of doing this without hacking things up???
Hissing Cobra
798
Massachusetts
Oct 18, 2007
  • Oct 18, 2007
Yes, you can buy new u-joints and a shaft and weld them together. Of course, this method won't contain a rag joint. You can probably make your own for less than $25.00. Otherwise, you could buy a Flaming River steering shaft kit (contains both joints and the shaft) but it's expensive. I bought mine for $189.00 and afterward, I saw that other people have made their own for a lot less money.
fastford91
254
Niagara ,Ontario, Canada
Oct 18, 2007
  • Oct 18, 2007
stick a pry bar in between and give it a yank till it doesnt hit anymore! as for restricting the flow!!! i highly doubt that it will make a difference in horse power! not likely at all! its not like your bending it 90 degrees or something! it wont hurt it at all!
1980coupe
CHICAGO
Oct 18, 2007
  • Oct 18, 2007
thanks for the advice guys!!! HISSING COBRA that is one sweet ass machine bro! realy freakin nice! you dont see them like that any more!
Hickfied
413
Morganton, NC
Oct 18, 2007
  • Oct 18, 2007
hissing, do you know where to get the u joints to make your own, possible for a manual rack also?
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Oct 18, 2007
  • Oct 18, 2007
I would loosten the shaft and heat the header tube till it's red hot than push the shaft against it till it mushes inwards about 1/4 of an inch than the shaft will not hit. and it would look cleaner than a bunch of dents from a prybar.
I also remember reading on here that someone loosen'd the shaft and moved it somehow and snuged it back up and it moved it somehow away from the header tube
Hissing Cobra
798
Massachusetts
Oct 19, 2007
  • Oct 19, 2007
I believe that Jeg's and Summit Racing both sell the u-joints. The problem is, you will need to know what size to use and the splines will need to match the rack.
RUNINAGT
237
CHARLESTON S.C.
Oct 19, 2007
  • Oct 19, 2007
We had that problem installing me shortys. We just bent the headers some. No problem after that. We found the issue during installation, so it was kinda easy. Easy because we had the header in our lap.
Exhaust 1 3/4” Long Tubes on a Fox Body AOD – Easiest route?
  • 5.0 Mike
  • Mar 19, 2025
2K
Fox 5.0 Mustang Tech Mar 21, 2025
5.0 Mike
Suspension 87 steering wheel slightly wobbles after new Rag joint install
  • R82148V
  • Jun 16, 2025
Fox 5.0 Mustang Tech Jun 24, 2025
R82148V
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
SN95 The Unicorn
  • HANO Motorsports
  • May 18, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 15, 2025
HANO Motorsports
F
Hydroboost Issues As Usual
  • ForeverDrivin
  • Aug 4, 2024
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Aug 10, 2024
ForeverDrivin
F
