Steering Shaft vs. Header Clearance
Dean85GT said:
But by raising your engine up with this not affect the driveshaft angle?
Agreed. Raising the engine is only going to create more problems. You need a certain angle to keep the pinion angle correct. You want really no more then -3 to -4 degrees tilt to the engine. Raising the engine is going to throw the whole shabang out. Just get a FR steering rack and call it a day. Or go get some double d shaft and some knuckles at the local hot rod shop and make your own.
Daggar said:
That'll probably be the ticket. I'll need to shake in there and verify the size of the spacers that are in there now then go maybe 1/4 inch additional on the plates. I'll also likely need ot order some longer bolts.
If you get theese made please post some pics. Im sure i will endup needing some made in the future.
$uperstang said:
Under your dash near the steering wheel there are a couple bolts that you can loosen and move the steering wheel ever so slightly toward the side you would need clearance on, it may help out.
I would do and have done this. Moves the steering column over. Should give you the clearance that you need.
Update:
Sure enough... I loosened the screws for the steering column and wedged a broom handle in between the header and the shaft. I took all the nuts off and coated the stud threads with blue locktite and reinstalled and cranked the crap out of them. I now have about 1/4 inch of clearance between the narrowest space between those two parts.
Thanks a million to everyone who responded!!! :nice:
