  • SN95 4.6L Mustang Tech
Steering still shaking
  • Thread starter Thread starter merc123
  • Start date Start date Oct 23, 2006
merc123
420
North GA
Oct 23, 2006
  • Oct 23, 2006
My steering wheel still shakes between 40 and 50 MPH. It shakes a little bit above that but not as pronounced at between 40 and 50. I crawled up under there yesterday when I changed my oil and I can't see anything wrong with the rack or the bushings. Everything was intact. The wheels were just recently put on and balanced so I'm not sure what else to do.
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Oct 23, 2006
  • Oct 23, 2006
Wheel balance is off.
Superhereaux
chicks make me feel inadequate
538
South Texas
Oct 23, 2006
  • Oct 23, 2006
if they're already balanced, try rotating them
you might have a bent wheel up front
merc123
420
North GA
Oct 24, 2006
  • Oct 24, 2006
2 different size wheels
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
Oct 24, 2006
  • Oct 24, 2006
either a bent rim or more likely the wheel balancing was not done right.
DTNODYA
831
  • Oct 24, 2006
My mom has a Grand Marquis ... long story short, her steering was vibrating. So the first thing I did was even out her tire pressure (because that will cause it too). She said it fixed it. The next day it came back. Turns out that the place that was balancing her tires did it WRONG 4 separate times. I took it to the dealership I used to work at ... problem solved.
So, now I check the tire pressure everytime after I have my tires mounted/balanced because after she had her's done, the pressures were like 17, 22, 29, 26 ... big time wtf.
merc123
420
North GA
Oct 24, 2006
  • Oct 24, 2006
I'll verify the tire pressure. I was cruising at 80 MPH today on the interstate and it was VERY smooth. No shaking or even vibrations. Who knows
Superhereaux
538
South Texas
Oct 24, 2006
  • Oct 24, 2006
well that should rule out a bent rim
shaking will get worse the faster you go
take it back to the place you had it done and have them do it again
madmatt
Ellis Juan sympathizer
465
Lexington, SC
Oct 25, 2006
  • Oct 25, 2006
Yea, Id say have them rebalance, if its not right still, take your money elsewhere. I had one of the bigger shops in town install the tires on my bullitts, and it shook like mad, took it to a smaller shop, smooth as glass.
merc123
420
North GA
Oct 25, 2006
#10
  • Oct 25, 2006
  • #10
This is the best shop in town I won't go to the other one. I may stop by the national tire (NTB?) in Atlanta on my way to work one day.
tjmaxx
157
#11
  • Oct 25, 2006
  • #11
Yeah it sounds like you didnt get your wheels balanced correctly I had this same problem with my old car. You get to around 45-50 and you can see and fat on your arm moving
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
J
Severe shaking/vibrations in steering wheel
  • jacket999
  • May 20, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jun 1, 2025
NtheGAME
N
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
