steering wheel alignment
candphall
5 Year Member
Jun 8, 2009
487
32
49
Orlando Florida
Is anyone aware of an alignment mark on the steering wheel and steering shaft that should be matched to properly align the steering wheel spoke down. So as an example if I have 4 turns full left to full right, two tuns should should center the the front wheels. If they are not is a tie rod adjustment. Is there a mark on the shaft that should match the steering wheel in that position. I cant find one on the steering wheel.
  • Sponsors(?)
horse sence
That $5 hooker turn out to be a guy
3,932
233
Wile Coyote's stunt double
The early years do have a mark but i dont remember if the 69 does .
The drag link and steering box should be centered before alignment . The tie rods should be brought into alignmen together side for side ,if one side is left longer than the other the steering will have a shorter throw from one side to the other. Once the alignment is finished and you are satisfied you have an equal turn radius ,then you can center the steering wheel
