steering
  • Thread starter Thread starter 86mustang5.oh
  • Start date Start date Aug 17, 2005
86mustang5.oh
125
battle creek mi.
Aug 17, 2005
  • Aug 17, 2005
is ther a way to tighten up the steering a lil bit on my car so it turns a lil faster i was driving a 03 today and it had pretty cool steering please help me
QDRHRSE
1,590
Palmdale, CA
Aug 17, 2005
  • Aug 17, 2005
You can do a few things. You can get a solid rag joint, urethane or solid rack bushings, a quick ratio rack and or replace all the control arm bushings....what esle is there?
K
Kerpal
400
  • Aug 17, 2005
Who sells upgraded rag joints for our cars? All I've been able to find is entire steering shafts for $150-200... which is a little much if I could just replace the joint with something solid.
I've heard a bumpsteer kit helps to tighten up the steering, but I don't know if that's just because of the improved geometry on lowered cars, or if the people that noticed a big differece were likely replacing worn out tie rod ends. I'm installing one right now, so I'll let you know the results...
New ball joints can only help, same for any of the front end bushings, especially if you go with solid or polyurethane ones...
Then there's subframes to stiffen up the chassis, lower profile tires for less sidewall flex, stiffer springs & shocks to control body roll... how involved do you want to get?
90mustangGT
I felt sorry for girls because
2,773
17
89
Dallas, GA
Aug 17, 2005
  • Aug 17, 2005
First of all, you want to find out where the problem is, not just throw parts at the issue. If something is worn out, that can make a difference. That includes struts, springs, swaybar links/bushings, controll arm bushings.
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
D
Loud noise(s) from Engine Bay
  • DuluthFoxbody
  • Oct 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 5, 2026
AeroCoupe
2003 gt, clutch pedal stiffness.
  • 2003 mustang gt modded
  • Feb 15, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 17, 2026
O
Suspension Extremely Quick / Light Steering
  • Okie
  • Oct 21, 2025
Fox 5.0 Mustang Tech Oct 22, 2025
AeroCoupe
G
79 steering rack problems
  • garyrc
  • Mar 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 8, 2026
AeroCoupe
