Power rack I assume. If so, the alignment specs that Steeroids recommends for a street car are:
Camber: 0 to -1/2 degree
Caster: 3 to 4 degree
Toe: 1/16" to 1/8" toe-in
I agree though with the previous post that camber could go up to -1 degree, and I would set the toe at 1/8". Your caster setting is out of spec for what Steeroids recommends but I would not think 2.2 degrees would cause what you described. Also, check that everything is tight in the steering system from the wheel to the spindles. There is also a slack adjustment which sets the gear lash between the rack and the pinion gear. It is located on the back side of the rack in line with the input shaft from the steering wheel. To set it you have to loosen the lock nut, tighten the adjusting screw snug and then back it off a little (about 1/8 turn). I have not personally done this adjustment on a J-car rack, but have done it on others.
