Stero-Antenna Question
Vyx
I installed an Alpine CDA-9856 in my '95 GT the other day and I have a few problems.
First, When I first turn on my car, before the CD/Tuner starts playing there is a "thump" sound that comes from the speakers. I was told this might be the grounding. If this is the case, how do i ground it? I used two metra harnesses to connect it and the ground off of the head unit is wired into the harness. How do i go about grounding the head unit?
Second, While installing the head unit, I inserted the antenna connection and then pulled it out again. Only problem is when I pulled it out again, the metal end piece came off in the antenna adapter on the head unit and I was left with a bare copper wire. Where can I get a replacement for this?
Thanks
