alright, this is just confusing the heck out of me. i just installed a tfs street heat, with a holley 70mm tb and 70mm egr spacer. when i first started it up after the swap, it ran fine but had a really loud rattling noise, tore it all apart and found that the plug on the drivers side of the upper plenum was loose, tightened, threw it all back together, and that noise was gone. timed it, seemed to be running ok, but noticed that the throttle pedal was really stiff. figured it was just the new spring on the throttle body and all was well untill it started sticking, and it would do it at any rpm unless i tapped the pedal and it would unstick. however, with the motor off, the throttle is nice and loose feeling like it was with the stock tb. i cannot for the life of me figure out why its doing this.
also, when shutting the car off theres a nice whistle sound coming from around the intake, guessing vac leak to hunt down? wasnt there untill i tore it apart the second time, dont know if it has anything to do with previous problem or not?
