I guess I'm bringing this one back from a few months ago.. I need answers, hopefully someone can help..
I have a long story that goes along, that has a lot of insight, so please bear w/ me..
All started 2-3 years ago... I had to get the rear diff rebuilt since the whirring was terrible. Turned out to be an axle seal went bad, and I lost all the fluid over the course of a few months..
Well, shop rebuilds the rear-diff, but incorrectly. It slightly damages my 3.73's but as long as my Eaton LSD is fine, I don't mind a little gear noise.. Problem is, ever since then, I've had the vibration coming from what seems to be the middle of the car..
Fast forward to last Fall. Since I was sick of the noise, and it seemed to get slightly worse, I brought it to a good friend who took a look.. He recommended U-Joints. initially, since he didn't really get dirty that day.. After swapping them, I notice the vibration is a little worse.. He gets back under the car w/ me, and sees the tranny mount is trash..
I replace it. Most of the vibration is gone, but it's still pretty bad from 50-85mph, then it goes away. Gear noise is still present, so I re-shimmed my rear-diff. Noise is still there...
So.... Recently, I got a bunch of money, and decided to do the right thing.. Replace my entire suspension. Well.. No dice.. STILL have vibration, and I think it's causing the pinion seal to separate from the housing, and I'm getting a little oil spray right about the diff..
I replaced the U/LCA's, Shocks/Struts, Rims/Tires, Tie-rod ends, brakes, wheel bearings, hardware etc.. I mean, the only things original about my car are the engine itself, driveshaft and the paint on the rear of the car...
So I searched for rear-axle alignment, to see if maybe that is off. How does one go about aligning a solid rear axle?? Is it all toe-in/caster adjustments??
Any help would be huge!!!
JT
JT
