Still having vibration problems...NEED HELP!
  • Thread starter Thread starter stang1986GT
  • Start date Start date Oct 31, 2007
stang1986GT
143
Charleston, WV area
Oct 31, 2007
  • Oct 31, 2007
Hey folks, I have an 86 GT, all stock, stock gears etc. When I slow down to a stop, it feels like the rear end is vibrating...kind of like when you hit those rumble strips on the emergency lane of the interstate, but not that severe. Any ideas on what to check and how?
LX302
Stanger
728
Bethlehem PA
Oct 31, 2007
  • Oct 31, 2007
Look at your U-joints first. You have 2 of them on the driveshaft. One at either end. One or both might be binding.
stang1986GT
143
Charleston, WV area
Oct 31, 2007
  • Oct 31, 2007
Well, I check the ujoints for looseness, and they are fine. How can I tell if they are binding? Just roll the drive shaft around?
PUNISHER RACING
1,124
FORD CITY, PA.
Oct 31, 2007
  • Oct 31, 2007
Sound like your rear end is taking a dump
Mikey1968
232
Kommiefornia
Oct 31, 2007
  • Oct 31, 2007
If brake pedal related, warped drums, maybe?
Other ideas....rear wheel bearings bad, loose lug nuts, worn axle bearing surface, damaged c-clip groove on axle, bad control arm bushing(s), worn rear shocks, rear brake hardware damaged or missing, low tire pressure, tire with a separating belt, low diff fluid....
I dunno, outta ideas......
Blown331LX
227
Chapel Hill, NC
Oct 31, 2007
  • Oct 31, 2007
Have you rear drums resurfaced or replaced, then the brakes adjusted, if they are still in good shape. If not replace the shoes and hardware also. This will make a big difference, its cheap and it is also regular maintenance. If it was anything related to the rear axle, springs, or control arms you would also have noises and vibrations while driving forward or on acceleration. A local shop could do this for around $100-$350, if you have the skills and tools u can do it for around $40-$120.
stang1986GT
143
Charleston, WV area
Nov 1, 2007
  • Nov 1, 2007
I need to check a lot of things. It doesn't seem to do it all the time, so I don't know if it's the rear end or not. Maybe it is, because it doesn't seem to do it when the car is cold...I don't know. No time to mess with it! GRRR!
I did notice the bushings on my quad shocks are shot on one side...maybe this is it. Thing is, they've been like that a long time.
Thanks for your help guys...I appreciate it.
Blown331LX
227
Chapel Hill, NC
Nov 2, 2007
  • Nov 2, 2007
Using a standard process of elimination like you would when doing a diagnostic. Think about it like this, if it only happens when braking its in the brakes, if you feel it behind you then it is the rear. As far as it being intermintent it will more than likely be in you rear brake hardware. Something like a broken spring, frayed cable, stretched retainer, or the brake shoes could be "corkscrewing", mechanic term.
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
Tuners come on inside
  • squeak93
  • Feb 13, 2026
  • SVT Tech Forum
SVT Tech Forum Feb 20, 2026
squeak93
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
