  • 1994 - 1995 Specific Tech
Still ****ing Overheating!!!!!!!!!
  • Thread starter Thread starter Guero
  • Start date Start date Aug 5, 2006
First Prev 2 of 2
F
fordtech28
312
Riverside Cali.
Aug 7, 2006
#21
  • Aug 7, 2006
  • #21
it depends how they are crossed I cross two wires one time it was lacking power and wasting alot of fuel so I checked my firing order and sure enough i have two cylinders that were opposite from each other crossed but the weird thing was it wasn't misfiring but I could smell the headers and when I opened the hood they were glowing orange so what was happening the cylinders weren't firing at the right time so there was alot of unburned fuel being dumped which causes the glowing effect
9
90bluegt
592
#22
  • Aug 7, 2006
  • #22
If the headers are getting red then you are probably running pretty lean. You are running twisted wedge heads, what size injectors are you running, What's the fuel pressure, is the engine pinging?
358stroker
62
Austin, TX
Aug 7, 2006
#23
  • Aug 7, 2006
  • #23
My headers were glowing once too. I figured out that I had my thermostat in backwards. Make sure your thermostat is installed correctly.
Guero
2,148
Aug 7, 2006
#24
  • Aug 7, 2006
  • #24
i doubt i running lean, 30lbs injectors, 255 pump, and the pressure is at 39lbs. Thermostat goes in with the spring towards the intake right?
No pinging, maybe my wires are crossed, But were both side of the headers glowing on yours to? I was thinking i was running to rich and thats why the headers were glowing. But your idea makes sense, ill double check the firing order. what is it by the way? i also think im lacking power.
OrangeMustangGt
1,976
Cape Cod, MA
Aug 7, 2006
#25
  • Aug 7, 2006
  • #25
how about a blockage somewhere....try flushing the block and radiator, etc.....
i would use a hose and make sure you got decent flow.
Guero
2,148
Aug 7, 2006
#26
  • Aug 7, 2006
  • #26
radiotor is new. I called my friend mechanic and said the rockers might be on to tight, is that a possibility of overheating? how would i know if i have a blockage? I know the water is flowing
Guero
2,148
Aug 7, 2006
#27
  • Aug 7, 2006
  • #27
Wires aren't crossed either
358stroker
62
Austin, TX
Aug 7, 2006
#28
  • Aug 7, 2006
  • #28
When I had my thermostat in backwards both headers were glowing, when that happens zero coolant is flowing through the heads so the motor can't get cooled down.
Guero
2,148
Aug 7, 2006
#29
  • Aug 7, 2006
  • #29
my coolant is flowing, im sure of that
Guero
2,148
Aug 7, 2006
#30
  • Aug 7, 2006
  • #30
so wtf is wrong?
First Prev 2 of 2
L
Car has been overheating. Not sure what is causing it. Any help would be appreciated.
  • Luckysgirl
  • Jun 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 2, 2026
Luckysgirl
L
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
G
2016 GT, Cold Air/Tune Trouble (overheating) . Advice/Help Please!
  • GLStang
  • Sep 6, 2025
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Sep 6, 2025
Dipstick Issue?
  • Sonic
  • May 2, 2026
1994 - 1995 Specific Tech May 5, 2026
WhiteCobra95
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
