Still missing :(
  • Thread starter Thread starter MoneygrubbinCar
  • Start date Start date Oct 4, 2007
M
MoneygrubbinCar
155
Jacksonville
Oct 4, 2007
  • Oct 4, 2007
I went to drive to work this mornin after feelin the slight miss I had over the weekend and problem has gotten a little worse. So I went on ahead changed the cap and rotor plugs and plug wires and I still have a pretty bad miss. Car is a stock 88 gt. I'm still learnin about these so some questions may be stupid but do the fuel injected 5.0's come with a choke? Would it be possible to have the choke sticking on the car causing the bad missing granted I have a choke. Also could it be 02 sensors I dunno if the car has these either? I don't have a timing light so i can't really look at that either. Please help a.s.a.p cars kinda my only transportation.
myslo50
247
ohio
Oct 4, 2007
  • Oct 4, 2007
check the tfi mogule on the dizzy, check fuel pressure, check injectors, if one is not working, check injector pulse w/ noid light. check compression check for codes, check vacume leak
M
MoneygrubbinCar
155
Jacksonville
Oct 4, 2007
  • Oct 4, 2007
I searched around a little and the tfi looks like a simple replacement if I was lookin at the right stuff. Just for a little schoolin what does (tfi) mean and what exactly is the dizzy? I see it all the time in the threads just never knew what exactly it is. Also I noticed Pip being mentioned a good bit whats that? Thanks for the help guys hopefully I can get this sorted out by the weekend.
M
MoneygrubbinCar
155
Jacksonville
Oct 5, 2007
  • Oct 5, 2007
anyone?
D
Daggar
3,902
  • Oct 5, 2007
First... you don't have a choke on an EFI car.
Next... try removing your spark plugs one at a time (motor off).
Strip the boots off the end of the wires (carefully) and inspect the terminal ends for rust/corrosion.
If you see some, wire brush them and use some Mothers (or equivalent) chrome polish along with half a q-tip on the end of a dremel drill to polish them to a mirror finish.
It might sound stupid but you'd be suprised how many times this little trick has worked and it doesn't cost you anything to try.
D
Daggar
3,902
  • Oct 5, 2007
Dizzy = Distributor
TFI= Thin Film Ignition Module
M
MoneygrubbinCar
155
Jacksonville
Oct 6, 2007
  • Oct 6, 2007
Thanks for clearin that up for me daggar.
9
91foxbod50
486
  • Oct 6, 2007
Just wondering. what kind of gas are you runnin?
dragnazz5.0
My "0" key d0esn't w0rk, s0 I have t0 use the zer0
Nov 19, 2005
815
mooresville, nc
Oct 6, 2007
  • Oct 6, 2007
do what the others have said about checking fuel pressure and codes...also the coil might be going bad. as the insulation or wiring inside the coil breaks down it will still fire but will miss as engine load increases. there are resistance values out there for the primary and secondary circuits in the coil.
ls1beater4eva
334
mooresville
Oct 6, 2007
#10
  • Oct 6, 2007
  • #10
i would check out the resistance on the coil, to make sure the line for your pcv isnt dried out and splitting apart allso. Its nice to see that u got your "o" key fixed draggonazz
dragnazz5.0
Nov 19, 2005
815
mooresville, nc
Oct 6, 2007
#11
  • Oct 6, 2007
  • #11
yeah its fixed...i just cant seem to get rid of this ct
M
MoneygrubbinCar
155
Jacksonville
Oct 6, 2007
#12
  • Oct 6, 2007
  • #12
I only run 93 octane in it. I noticed it with a little labor knock under low rpms so I just went ahead and started puttin 93 in it and it went away. I guess I'll pull codes after I look at the coil.
dragnazz5.0
Nov 19, 2005
815
mooresville, nc
Oct 6, 2007
#13
  • Oct 6, 2007
  • #13
sounds like the engine runs a little warmer than normal or there is carbon buildup in the combustion chamber....try running some engine cleaner through the gas tank...like lucas or seafoam and see if that helps the car at all.
M
MoneygrubbinCar
155
Jacksonville
Oct 7, 2007
#14
  • Oct 7, 2007
  • #14
Car is fixed I guess when i was running on E one day from work the car sucked up some trash and I caught wind of it the next time I went to drive it. Simple fuel filter replacement problem gone. Just a heads up and another thanks for the help.
  • brandyn200
  • Jun 20, 2026
AeroCoupe
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
Brakes 80 Mustang 4.2 rear chassis brake line for 5 lug conversion!
  • StangPowerLSX510
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 9, 2026
limp
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Dakar09
D
Engine Another no start after washing engine bay
  • bruno
  • Apr 26, 2026
Fox 5.0 Mustang Tech May 7, 2026
AeroCoupe
