Still need help!
jlds91389
241
Orange Tx
Ok guys im back with the same vibration as my earlier post. I pulled the rear end from the car and took it about thinking it was bent axles. Replaced both axles,seals,bearings. also replaced pinion bearing,seal,crush collar, and nut.Got the preload i need on the pinion so its good there. My problem is the vibration is still there. It gets worse with speed. Could this be the driveshaft is out of wack? i have been running theses 4.10s for about 2 years with 0 problems. If it was the shaft shouldnt it have started earlier on? Would it be a good idea for me to get an aluminium unit? just need some help here. thanks
I chased a bad vibration in my 02 gt for a while. I had my tires balanced 3 times and it still had a vibration. 4th time I went to a different shop and he hooked it up to the roadforce and it got better but was still there. I then replaced my shocks and vibration was gone. Shocks were blown.
nope rear control arms are stock but i did find the problem. I had two bent axles and my companion flange was a little warped. I put everything back together and rotated my driveshaft 180 jsut to see took out almost all the vibrations. Maybe a new driveshaft will take it all out:shrug:
