  • 1994 - 1995 Specific Tech
Still running like crap part 2
  • Thread starter Thread starter Guero
  • Start date Start date Jun 26, 2007
1 of 2 Next Last
Guero
2,148
Jun 26, 2007
  • Jun 26, 2007
So after replacing my ECT and IAT, and my coil and distributer and TFI it still ran like ****. Computer still pulls timing down to 10*. So I decided to put my timing at 25* and run without the spout. It still ran like ****!!! My rpms were acting up going from like 4k to 6k in a blink of an eye then backfiring. I quickly stopped and went back home slowly. What else should I do????
By now most of you are tired of me lol!!! Imagine how I feel that I actually have to work on it!
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
Jun 26, 2007
  • Jun 26, 2007
you pulled your plugs to check them? how they look?
what your discribing sounds exactly like when i had 2 plug wires mixed up
bad injector? can you swap the stockers back in for a test?
Guero
2,148
Jun 26, 2007
  • Jun 26, 2007
I will check them. I haven't checked my injectors but I am running rich. its in the 13's and 12's at part throttle and usually never sees 14.
BlueOvalStangGT
2,849
Tampa Florida....USF!!!
Jun 26, 2007
  • Jun 26, 2007
Did you datalog ECT yet?
Guero
2,148
Jun 26, 2007
  • Jun 26, 2007
Yes I did. Hottest it got was 210. Even when it was at 140(Ithink that was the lowest) when I first started it still ran the same. Pulled timing.
BlueOvalStangGT
2,849
Jun 26, 2007
  • Jun 26, 2007
What do the other sensors look like? ACT? A/F?
Guero
2,148
Jun 26, 2007
  • Jun 26, 2007
ACT reads in 100's* A little hotter or colder depends if Im at a light or at speed. A/f reads in the 13's 12's at idle or part throttle. Like I said its not right cuz its usually at high 14's.
Guero
2,148
Jun 26, 2007
  • Jun 26, 2007
How bout a bad MAF?
HISSIN50
34
129
Jun 26, 2007
  • Jun 26, 2007
Guero, I'd continue to pursue the timing aspect. How poorly did the car run? It should have run halfway decently (note that I havent run a locked timing car at 6K RPM though ).
When your SPOUT is intalled, If you change the global spark in the TwEECer, does that do anything? If you are defaulting to 10*, can you just shift your spark tabling instead?
Guero
2,148
Jun 26, 2007
#10
  • Jun 26, 2007
  • #10
The car ran decent till about 3k. When it backfired and the Rpms shot up to 6k in a blink of an eye were i stopped and went home. What do mean shift my table?
urban96
3,464
Syracuse, NY
Jun 26, 2007
#11
  • Jun 26, 2007
  • #11
when your under any kind of load does it backfire?
i know u said u checked the wires but what your discribing is exactly what happen to me when i had 2 of em mixed up
Guero
2,148
Jun 26, 2007
#12
  • Jun 26, 2007
  • #12
No I know what that feels like Urban. Im sure its not that. With the spout no. It just feels like it sputters and revs up really really slow!
urban96
3,464
Syracuse, NY
Jun 27, 2007
#13
  • Jun 27, 2007
  • #13
maybe its a bad ECU
Guero
2,148
Jun 27, 2007
#14
  • Jun 27, 2007
  • #14
That would be my last guest to. Im going tomorrow to a Mustang shop and see if they can help
urban96
3,464
Syracuse, NY
Jun 27, 2007
#15
  • Jun 27, 2007
  • #15
if you were local i still have my stock ECU you could swap in to see if that was the culprit
Guero
2,148
Jun 27, 2007
#16
  • Jun 27, 2007
  • #16
Im going junkyarding tomorrow. Hope I see a 94-95 Mustang!!! It has to be stick to correct?
urban96
3,464
Syracuse, NY
Jun 27, 2007
#17
  • Jun 27, 2007
  • #17
since u have a tweecer u can turn off the auto stuff
Guero
2,148
Jun 27, 2007
#18
  • Jun 27, 2007
  • #18
urban96
3,464
Syracuse, NY
Jun 27, 2007
#19
  • Jun 27, 2007
  • #19
if you get an auto computer itll work, just adjust the settings for when it wants to shift
HISSIN50
34
129
Jun 27, 2007
#20
  • Jun 27, 2007
  • #20
Regarding what Urban is talkin about, the prompt is something like a:
Trans load type switch.
An AODE is 6 and a stick is 0 or something like that (just thrown out for people to shoot down ).
If you cannot get the computer to advance the timing with the SPOUT installed, and the wiring doesnt have an open (check it at the computer, because a cut wire or loose pin will create this issue), then the puter is likely bad. Otherwise, we hate for you to waste a day at the junkyard for nothing.
Good luck bud.
1 of 2 Next Last
J
Engine Tuning...?
  • justadude07
  • May 30, 2026
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
M
Running rough
  • Mike3
  • Dec 31, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 1, 2026
Mike3
M
Engine 91 mustang 302 Low acceleration car backfires pops and acts like it doesn’t want to take fuel
  • 1991Fox5.0
  • Oct 4, 2025
Fox 5.0 Mustang Tech Oct 6, 2025
1991Fox5.0
  • brandyn200
  • Jun 20, 2026
AeroCoupe
