  • 1994 - 1995 Specific Tech
stock 1/4 mile
  • Thread starter Thread starter StangGT4U
  • Start date Start date Mar 15, 2004
StangGT4U
14
  • Mar 15, 2004
I'm a new member and I barely got the car its a 94 Mustang GT and was wondering what the stock typical 1/4 mile would be for these yearswith a good driver and 5 speed? I have a lot to learn and so I will probably start posting alot of stupid questions but hey I have to learn some how right. WEll before I got the Stang I had a Mitsubishi Eclipse GSX AWD Turbo which I loved and still wish I had that thing pulled like crazy it had simple mods to it just free mods and 3 in exhaust system with a MBC (manual boost controller) it was running i would probably say a low low 13 some of the cars it smoked was a 91 5.0, 99 Z28, SRT-4, and lost to a TT RX7 but enough about that just post some completely stock numbers or some basic bolt ons like an intake and exhaust thanks.
sldghmr
291
Sil Sprg, MD
Mar 15, 2004
  • Mar 15, 2004
Welcome. The Mustang takes a little getting used to launching out the gate (no more rev it to the moon and let AWD carry you away), but once you master it I'd guess a mid 14 to be pretty good for bone stock. Good luck....
C
CivicEater
579
  • Mar 15, 2004
what year was your Mitsu? what boost were you pushing? those things have intercoolers stock right?
StangGT4U
14
  • Mar 15, 2004
Yea a mid 14 would be good but I dont think these can get a mid 14 bone stock amybe with an intake and exhaust? But acrtually the Eclipses are not high rev engines u shift almost at the same point i think but i shifted at 6k every gear.
sldghmr
291
Sil Sprg, MD
Mar 15, 2004
  • Mar 15, 2004
I had Flowmasters only and was running 14.7's and 8's spinning. Keep at it. It is a delicate balance.
StangGT4U
14
  • Mar 15, 2004
I had a 92 the 1g 7 bolt motor and was probably running like 25 psi stock which is crazy ur only supposed to run 17 psi max stock but hey it did no damage it was bad ass!!!
StangGT4U
14
  • Mar 15, 2004
Damn!!! just a flowmaster and thats it? Thats crazy what did u launch at and what type of tires were you using and shift points?
sldghmr
291
Sil Sprg, MD
Mar 15, 2004
  • Mar 15, 2004
I was leaving at about 2k and slipping the clutch while rolling into the throttle. Speed shifted 2nd and 3rd around 5k rpm. Just recently found out that my tach is a little further off then what I thought, so your going to have find your shift points. Definitly do the "10 min" tune up. Helps a ton....
StangGT4U
14
  • Mar 15, 2004
Alright will work ill practice that does anyone else mind posting up the stock 1/4 mile times???
Zero Signal
2,633
Tucson, AZ
Mar 16, 2004
#10
  • Mar 16, 2004
  • #10
You probably won't break into 14's bone stock. Most of the 94/95's run mid to low 15's bone stock. I guess you could see a mid 14 with gears and a couple other minor bolt-ons.
randomjoker
427
Oklahoma
Mar 16, 2004
#11
  • Mar 16, 2004
  • #11
with gears alone you would break 14s... bone stock: low low 15's
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
M
Progress Thread mkk50's Progress Thread
  • mkk50
  • Aug 4, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 22, 2025
Hello fellow Mustang fanatics.
  • 580HP*428Cj
  • Apr 2, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 18, 2026
josep4
