Stock Fuel Pump
  • Thread starter Thread starter 155dB5.0
  • Start date Start date May 20, 2014
155dB5.0
165
Upper MI
May 20, 2014
  • May 20, 2014
Still running stock pump on my hci set up, how much power and performance am I missing with it?
RangerJoe
I leave the horn on while driving
2,560
1,146
184
Georgia
May 20, 2014
  • May 20, 2014
I don't know, lol. I just put a 255 pump in over the weekend because I had no idea what was in there already and I am getting ready to do my AFR swap. I think what I took out was the stock pump. I was really surprised, be caused based on my mph and vehicle weight, I should be a little over 300rwhp. I'm not sure what the limit of the stock pump is.
Joe
155dB5.0
165
Upper MI
May 20, 2014
  • May 20, 2014
I think it only supports around 250 and I should be around 350 flywheel with my mods I would think. I'm trying to sell the car and that got me thinking have I been missing out on some power.
R
reldla1996
356
22
Dayton, Ohio
May 20, 2014
  • May 20, 2014
It depends on how efficient your engine is, but if it's tuned efficiently, the stock pump will support around 300 hp. If you don't have enough fuel pump, you'll run lean at the top end, which if severe enough can lead to melting holes in your pistons. Pull a spark plug, and look at it closely for little silver spots (melted aluminum).
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
May 20, 2014
  • May 20, 2014
Copied from the FORD RACING PERFORMANCE PARTS catalog:
PROPERLY SIZING FUEL SYSTEM COMPONENTS
Fuel Pumps
The following information is presented assuming the above information has been taken into consideration regarding BSFC, fuel pressure and specific gravity of the fuel being used. Most fuel pumps for electronic fuel injection are rated for flow at 12 volts @ 40 PSI. Most vehicle charging systems operate anywhere from 13.2v to 14.4v. The more voltage you feed a pump, the faster it spins which, obviously, will put out more fuel. Rating a fuel pump at 12 volts then, should offer a fairly conservative fuel flow rating allowing you to safely determine the pump’s ability to supply an adequate amount of fuel for a particular application.
As previously mentioned, engines actually require a certain WEIGHT of fuel, NOT a certain VOLUME of fuel per horsepower. This can offer a bit of confusion since most fuel pumps are rated by volume, and not by weight. To determine the proper fuel pump required, a few mathematical conversions will need to be performed using the following information. There are 3.785 liters in 1 US Gallon. 1 gallon of gasoline (.72 specific gravity @ 65° F) weighs 6.009 LBS.
To be certain that the fuel pump is not run to its very limit, which could potentially be dangerous to the engine, multiply the final output of the fuel pump by 0.9 to determine the capacity of the fuel pump at 90% output. This should offer plenty of ‘cushion’ as to the overall “horsepower capacity” of the fuel pump.
To determine the overall capacity of a fuel pump rated in liters, use the additional following conversions:
(Liters per Hour) / 3.785 = Gallons
Multiply by 6.009 = LBS/HR
Multiply by 0.9 = Capacity at 90%
Divide by BSFC = Horsepower Capacity
So for a 110 LPH fuel pump:
110 / 3.785 = 29.06 Gallons
29.06 x 6.009 = 174.62 LBS/HR
174.62 x 0.9 = 157 LBS/HR @ 90% Capacity
157 / 0.5 = 314 HP safe naturally aspirated “Horsepower Capacity”
Safe “Horsepower Capacity” @ 40 PSI with 12 Volts
60 Liter Pump = 95 LB/HR X .9 = 86 LB/HR, Safe for 170 naturally aspirated Horsepower
88 Liter Pump = 140 LB/HR X .9 = 126 LB/HR, Safe for 250 naturally aspirated Horsepower
110 Liter Pump = 175 LB/HR X .9 = 157 LB/HR, Safe for 315 naturally aspirated Horsepower
155 Liter Pump = 246 LB/HR X .9 = 221 LB/HR, Safe for 440 naturally aspirated Horsepower
190 Liter Pump = 302 LB/HR X .9 = 271 LB/HR, Safe for 540 naturally aspirated Horsepower
255 Liter Pump = 405 LB/HR X .9 = 364 LB/HR, Safe for 700 naturally aspirated Horsepower
Note: For forced induction engines, the above power levels will be reduced because as the pressure required by the pump increases, the flow decreases. In order to do proper fuel pump sizing, a fuel pump map is required, which shows flow rate versus delivery pressure.
That is, a 255 liter per hour pump at 40 PSI may only supply 200 liters per hour at 58 PSI (40 PSI plus 18 lbs of boost). Additionally, if you use a fuel line that is not large enough, this can result in decreased fuel volume due to the pressure drop across the fuel feed line: 255 LPH at the pump may only result in 225 LPH at the fuel rail.
My Comments:
A lot of people oversize the fuel pump by buying a 255LPH pump thinking that the fuel pump regulator will just pass the excess gas back to the tank. It does, but… Did you ever consider that circulating the fuel around as a 255 LPH pump does will cause the gas to pickup engine heat? What happens to hot gasoline? It boils off or pressurizes the fuel tank! With most of the 5.0 Mustangs having the carbon canister removed or disabled, the car stinks like gas, and the gas mileage drops since the hot fuel evaporates away into the air.
155dB5.0
165
Upper MI
May 20, 2014
  • May 20, 2014
Looks like I should pull it with the above info.
155dB5.0
165
Upper MI
May 21, 2014
  • May 21, 2014
any more input on this, wanted to order for the weekend if needed.
Thanks
madspeed
Colonel Mustard
1,332
204
a van down by the river
May 21, 2014
  • May 21, 2014
If you're trying to sell the car, why are you spending money on it??
155dB5.0
165
Upper MI
May 21, 2014
  • May 21, 2014
Well i may end up keeping it if i don't have any interest in it, i have owned it for 16 years. So for the price of a pump and a few hours work if i will find some power i have been missing figured why not The tentative plan is if there is no interest i will stick more money into it. I don't have alot of free time now a days so they plan was to get something a little newer to play with like a terminator or vette.
madspeed
Colonel Mustard
1,332
204
May 21, 2014
#10
  • May 21, 2014
  • #10
you won't find any power with a fuel pump swap
madspeed
Colonel Mustard
1,332
204
May 21, 2014
#11
  • May 21, 2014
  • #11
I see, I missed your mods. With what you have listed, a 190lph is plenty, but the 255's are about the same price, hence the reason most go straight to them
155dB5.0
165
Upper MI
May 21, 2014
#12
  • May 21, 2014
  • #12
So the stock 88 is definitely hindering performance on my setup, im not sure if its showing my sig in every post or not. Also have 24lbs injectors
madspeed
Colonel Mustard
1,332
204
May 21, 2014
#13
  • May 21, 2014
  • #13
I doubt its hurting performance, although you may be running lean at the top end. Unsafe, but lean actually is a bit more powerful than fat
155dB5.0
165
Upper MI
May 21, 2014
#14
  • May 21, 2014
  • #14
Very true, probably just address then if I don't find a buyer. Thanks for the help
V
v8only
2,378
22
49
May 21, 2014
#15
  • May 21, 2014
  • #15
that stock 88 lph pump is killing you...it's enough for gt40 heads, but certainly not your heads. You're probably going way lean up top ...Just stick in a 255...what the engine doesn't use, it'll simply return to the tank.
Those 24's probably aren't big enough either. With ported heads, they're probably leaning out up top. A tune may be able to up the duty cycle on them, but you may be better off with 30's
155dB5.0
165
Upper MI
May 21, 2014
#16
  • May 21, 2014
  • #16
I ended up ordering the pump so I had something to do Friday after work lol
  • Mindseye007
  • Aug 16, 2026
Mindseye007
  • brandyn200
  • Jun 20, 2026
AeroCoupe
L
Engine 85 GT Excessive Idle
  • lutzkecj
  • Sep 18, 2026
Fox 5.0 Mustang Tech Sep 21, 2026
86HO5.0
W
Engine My engine dies after running 10 to 15 minutes under high heat.
  • Wylieone
  • Jun 21, 2026
Fox 5.0 Mustang Tech Jun 22, 2026
Mustang5L5
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
