Stock Gear Test!!
  • Thread starter Thread starter jstang209
  • Start date Start date Oct 25, 2005
J
jstang209
20+ Year Stangneter
Jun 3, 2004
640
Stockton 209
Oct 25, 2005
  • Oct 25, 2005
Is there anyway to find out if i have stock gears.. the guys i got the rear end from claims it has "performance gears" but dont no the ratio.. so yea.. any ideas?
9
90bronconate
124
Phoenix, AZ
Oct 25, 2005
  • Oct 25, 2005
jack the car up and see how many times the driveshaft turns per one revolution of the tire. 2.73 times = 2.73 ratio. 3.73 = 3.73 ratio. ect. ect.
bubba-dough
1,044
Indiana
Oct 25, 2005
  • Oct 25, 2005
put the car on stands and put it in neutral. spin the tire and see how many times the driveshaft turns compared to 1 turn of the wheel. example if it turns 3 3/4 turns to 1 of the wheel its 3.73.
HISSIN50
34
129
Oct 25, 2005
  • Oct 25, 2005
You will have to either mark and count axle flange vs pinion flange rotations or just open the pumpkin (remove cover) and count the ring teeth and pinion teeth to get your ratio.
Good luck.
T
tjm73
2,418
Rush, NY
Oct 25, 2005
  • Oct 25, 2005
What he said. This is the most accurate way short of opening the housing.
Another way would be with RPM at given speeds in a given gear. But your speedo would have to realitivly accurate to do this.
For example 3.73's with a 26" tall tire in 4th gear at 60 mph would tach at about 2900 rpm.
HISSIN50
34
129
Oct 25, 2005
  • Oct 25, 2005
Ok, I guess I need clarification. I thought he said he bought the rear-end piece-meal. I assumed it was not installed on the car yet. Maybe I am wrong.
bubba-dough
1,044
Indiana
Oct 25, 2005
  • Oct 25, 2005
True it isn't clear. But if its on the car or not he has the directions for both now....
K
Drivetrain '87 5.0 Installing New Ring Gear and Pinion - Pattern Questions
  • karhoot
  • Apr 23, 2026
Fox 5.0 Mustang Tech May 9, 2026
Mindseye007
Drivetrain 5th Gear Ratio
  • PonyGTrider
  • Dec 8, 2025
2K
Fox 5.0 Mustang Tech Dec 31, 2025
Qtrhrse23
3.08 gears with a manual trans
  • limp
  • Aug 27, 2026
  • 2 3
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
Qtrhrse23
Speedometer Calibration
  • Sonny Bibb
  • Sep 11, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Sep 13, 2026
Sonny Bibb
Drivetrain How much resistance, if any at all, is normal on a new 1st gear and synchro on a WC T5 transmission?
  • sleep-e
  • Jan 21, 2026
Fox 5.0 Mustang Tech Jan 22, 2026
sleep-e
