stock gears
  • Thread starter Thread starter pazur
  • Start date Start date Oct 21, 2007
P
pazur
82
northern Virginia
Oct 21, 2007
  • Oct 21, 2007
can someone advise what's the stock gear ratio in '67 rear V8?
ultrastang
1,092
Arkansas
Oct 21, 2007
  • Oct 21, 2007
If the driver's side door on your car hasn't been replaced, you can look at the tag on the back edge of the door. Look under the "AXLE" heading for the code letter.
Or, if the I.D. tag is still present on one of the (10) studs that holds the tag to the 3rd member-to-housing studs, you can read the ratio from it.
You can check this link at my site for codes and their corresponding ratios: http://ultrastang.com/Rearinfo.asp?Page_ID=5
D
D.Hearne
11,730
south louisiana
Oct 22, 2007
  • Oct 22, 2007
Small block, more than likely it's got 2.79's.
Drivetrain 5th Gear Ratio
  • PonyGTrider
  • Dec 8, 2025
2K
Fox 5.0 Mustang Tech Dec 31, 2025
Qtrhrse23
J
Rear alignment issues
  • Jayjay001
  • May 27, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk May 27, 2026
68 manual disc/drum master cylinder
  • Butchd88
  • May 27, 2026
1965 - 1973 Classic Mustangs -General/Talk- May 27, 2026
Butchd88
P
67 Mustang, with the 302 want to convert auto back to the original manual
  • Pdunn
  • May 3, 2026
Classic Mustang Specific Tech May 7, 2026
Mcmahst
K
Drivetrain '87 5.0 Installing New Ring Gear and Pinion - Pattern Questions
  • karhoot
  • Apr 23, 2026
Fox 5.0 Mustang Tech May 9, 2026
Mindseye007
