  • 1994 - 1995 Specific Tech
Stock plug gap
  • Thread starter Thread starter mytight95
  • Start date Start date Feb 13, 2004
mytight95
2,605
Dothan,Al
Feb 13, 2004
  • Feb 13, 2004
I have my plugs gapped at .045 is this right, i have also heard to gap them at .054 which of these is correct, also if you have your plugs undergapped what will this cause? I run autolite 25's so this should be a common plug for our cars correct. Trying to find the source of my popping misfire at low rpms. Also is there a way to check the voltage on the ECT sensor or the TFI (ithink) module to test them and make sure that they are good before replacing them? Is there anything else i should look for. I don't have a vibration, and i know it is not the balancer ----just replaced not long ago. I was also wondering if possibly it is the fuel pump cutting out, that said is there a quick way to check the status of the fuel pump and see how it is working.
Thanks
Jason
1105
I AM the random post master...bow down
May 3, 2003
3,841
Daytona Bch, FL
Feb 14, 2004
  • Feb 14, 2004
I'm pretty sure .045 is the right gapping for the plugs. As for your popping misfire, have you checked your timing at all? Advance it a little bit and see if it goes away.
mytight95
2,605
Dothan,Al
Feb 14, 2004
  • Feb 14, 2004
right now my timing is set at 10* and i only did that so that i could run 87 octane fuel, and i never did really notice that too much when the timing advanced, why would stock timing make the car sputter pop etc.
thanks 1105
jason
Rootus
Officially Addicted
Feb 8, 2003
6,659
Portland, Oregon
Feb 14, 2004
  • Feb 14, 2004
0.054 is stock.
mytight95
2,605
Dothan,Al
Feb 14, 2004
  • Feb 14, 2004
thanks hairy that's the most important thing that i wanted to know.
jason
  • Mindseye007
  • Aug 16, 2026
Mindseye007
W
Engine My engine dies after running 10 to 15 minutes under high heat.
  • Wylieone
  • Jun 21, 2026
Fox 5.0 Mustang Tech Jun 22, 2026
Mustang5L5
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
Engine 1994 5.0 refuses to idle
  • FordFanatic1894
  • Jul 20, 2025
1994 - 1995 Specific Tech Jul 22, 2025
General karthief
J
Spuddeeing 06 4.0!
  • jester242
  • Dec 22, 2025
2005 - 2014 S-197 Mustang -General/Talk- Dec 22, 2025
jester242
J
