Guero Active Member Oct 11, 2005 2,148 0 47 Oct 5, 2007 #1 Oct 5, 2007 #1 Is there any way I can I can test a wire to make the stock rpm dash move so I know what wire to cut into?? Like add power or ground it or something??
91LX_5L Founding Member May 13, 2002 1,943 0 36 British Columbia Oct 6, 2007 #2 Oct 6, 2007 #2 why are you installing a aftermarket tach, if so run a wire from your coil, more accurate. im sure if you put some voltage on it, it should rise, would it not?
Guero Active Member Oct 11, 2005 2,148 0 47 Oct 6, 2007 #3 Oct 6, 2007 #3 I will but not right now.....I just want my stock gauge to work....Im already running a wire from the MSD box to the inside....just wanted to know what wire the stock was since I cant find it....
