give or take a few hundred revsbock said:Is the stock tach give a good reading ?![]()
if i use a 6200 pin even if the stock tack is wrong,the shift light shoulb get on at 6200?
Scott W said:I used my msd 6al to test my tach. I put the 3000rpm pill in, and the car's tach read dead-on (3000rpm), when the rev limiter cut in.
I then tested the 6000 rpm pill, and my tach read 6500rpm before the rev limiter kicked in, so my tach is off my 500 rpm @ 6000 rpm. If I had more pills I could do a better job calibrating.
