Straighten axle tube???
you can send it to moser axle in indiana they can striaghten it ,unless its bent double or squashed its fair cheap to have done as well i think under 50.00 they can also put a brace on it to keep it straight IF NEEDED
Fox is shorter. Are you replacing everything inside? I'd be afraid that it damaged the axle and maybe the diff. I think Fox through 98 are the same housing. Brakes should interchange with the right axles. I have never tried 99+ brakes on a Fox. Mine is a fox housing and diff with 95 brakes and axles.
Were you planning on putting this rear in an early Mustang? If you were, you'd need to have it shortened anyway. It's way too wide in stock form. Also if the housing is bent, you most likely have at least one bent axle. The housing can be straightened by the shop that narrows it, but I don't think axles can be straightened.
Its got just a small scratch...itll buff out :rlaugh: Just 9k miles......
