  • 1994 - 1995 Specific Tech
Strange door lock issue
  • Thread starter Thread starter CJMcLean
  • Start date Start date Dec 31, 2010
C
CJMcLean
120
Houston, TX, USA
Dec 31, 2010
  • Dec 31, 2010
I believe it is the switch, but I want to get some other opinions before I drop $40 on the switch.
Both door locks open & close correctly from the driver switch. From the passenger switch, they act like they aren't getting enough juice. They make a strange noise, then slowly open & close after a few seconds. I used a test light and both sides of the switch are getting power.
Is it possible that the switch is still bad & barely putting power to the actuators? I know it doesn't make much sense - but I can't figure out why both actuators work fine with the other switch?
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Dec 31, 2010
  • Dec 31, 2010
The contacts inside the switch are probably dirty. I don't know if it's able to be disassembled, but it's worth a shot, to try and see. You might get lucky and fix it on the cheap, without replacing the switch.
N
Power door lock motor Question
  • NYFox
  • Mar 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 17, 2026
NYFox
N
J
89 mustang alarm install to lock and unlock
  • jk66
  • Apr 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 10, 2026
jk66
J
Engine Strange Noise
  • burntokita
  • May 8, 2026
Fox 5.0 Mustang Tech May 11, 2026
keel
Electrical Are there any aftermarket door lock actuators that actually work?
  • 89notchDude
  • Nov 24, 2024
3K
Fox 5.0 Mustang Tech Dec 2, 2024
FastDriver
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
