Strange idle problem
  • Thread starter Thread starter 1992blkGT
  • Start date Start date Jul 15, 2004
1992blkGT
523
Beaverton, OR
Jul 15, 2004
  • Jul 15, 2004
Here is the problem I've been having ever since I took off my lower intake manifold and then reinstalled it (it was leaking oil before): whenever I am coming to a stop, and put the car in neutral, it remains idling high (like 1500-1800 rpms) until I come to a complete stop. If I put the car in neutral to coast, the rpms remain high and won't come down until I either stop or put the car back in gear. Also, when I rev the motor in neutral it also very slowly idles down. Any ideas to what's causing this? I've heard some people say the throttle cable might be hanging up or that there might be a vacuum leak. Any of these sound plausible? Thanks for any help and mods are in sig.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jul 15, 2004
  • Jul 15, 2004
Look for vacuum lines that are missing or broken.
ironmedic
1,361
Puyallup, WA
Jul 15, 2004
  • Jul 15, 2004
yeah that happens to me every now and then, i shut the car down and turn it back on and it goes away.
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jul 15, 2004
  • Jul 15, 2004
Troubleshoot the throttle cable by disconnecting it and then revving the engine. When you open the throttle, you should feel the resistance of the throttle spring. When you feel the spring, let go and let the throttle snap shut. The revs should drop off quickly. You can also do this with the engine off and the air duct disconnected to watch the throttle butterfly move.
Strange timing issue
  • 92 Bimini Blue
  • Sep 26, 2026
Fox 5.0 Mustang Tech Oct 20, 2026
rednotch
Engine Strange Noise
  • burntokita
  • May 8, 2026
Fox 5.0 Mustang Tech May 11, 2026
keel
P
Fuel New Eldebrock 1406 problems 1985 GT 5.0
  • Paddyman
  • Oct 22, 2026
Fox 5.0 Mustang Tech Nov 2, 2026
manicmechanic007
F
Engine 1988 Foxbody idle issues
  • fernandosgarage55
  • Apr 28, 2026
Fox 5.0 Mustang Tech Apr 30, 2026
AeroCoupe
M
Idle control problems
  • miser143
  • Aug 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 29, 2026
DadLife0724
