Strange strut install problems...?!?!?
  • Thread starter Thread starter zidane45
  • Start date Start date Aug 12, 2004
zidane45
55
charleston,SC
Aug 12, 2004
  • Aug 12, 2004
I'm installing these struts and for some reason i cant get them to reach high enough to get the bolt on the c/c plates. i've put the jack under the end of my rotor and we've pushed down on the car....won't go.
any tips or help please...?
zidane45
55
charleston,SC
Aug 13, 2004
  • Aug 13, 2004
no help?
do i need to use a spring compressor?
Sevan
558
IL
Aug 13, 2004
  • Aug 13, 2004
just bring the strut up throught the fender and through the CC plates and bolt the strut loosly. then you will need a spring compressor to get the spring..good luck
zidane45
55
charleston,SC
Aug 13, 2004
  • Aug 13, 2004
has anyone else had to do this with struts before?
5literttop
229
Saint John, NB Canada
Aug 13, 2004
  • Aug 13, 2004
I did mine this spring and they were fine. The strut should automatically extend, mine did anyway. The stock ones that were wore out, did it too.
zidane45
55
charleston,SC
Aug 13, 2004
  • Aug 13, 2004
mine arent gas charged. they are strange 10 way adjustables. i have them extended all the way and when i jack the spindle and control arm up i still have like an inch to go to get the strut into postion to get the retaining nut on top.
this is with it attached to the spindle.
5literttop
229
Aug 13, 2004
  • Aug 13, 2004
Attach at the top and see if you can pull it down...
zidane45
55
charleston,SC
Aug 13, 2004
  • Aug 13, 2004
nope
the spring isn't compressing enough to reach.
5literttop
229
Aug 13, 2004
  • Aug 13, 2004
Get a spring compressor and use it to shorten the distance. seems odd you would have to do this. These are new struts?
zidane45
55
charleston,SC
Aug 13, 2004
#10
  • Aug 13, 2004
  • #10
yeah...strange 10 ways. makes me mad too
i had my old ones off a while. for like 4 days. so i don't know if that would have made a difference
Sevan
558
IL
Aug 13, 2004
#11
  • Aug 13, 2004
  • #11
I had to cut the bolts for the spring compressor to make it fit. If you have an air compressor use it to compress the spring because its tough if you doing it by hand....good luck and be careful
89MustangGX
I have nothing productive to add!
Jul 3, 2001
10,262
Mill Creek, WA
Aug 13, 2004
#12
  • Aug 13, 2004
  • #12
No problems like that with stock springs and Strange struts here. I did have an odd fitment problem with their shocks though...
zidane45
55
charleston,SC
Aug 13, 2004
#13
  • Aug 13, 2004
  • #13
thats wierd...my shocks went in like 10 minutes. crazy. i think it may be that i left the control arm lose for like a week. not sure. i picked up the compressor and we;ll see how it goes.
89MustangGX
Jul 3, 2001
10,262
Mill Creek, WA
Aug 13, 2004
#14
  • Aug 13, 2004
  • #14
My problem with the shocks -- if it was actually a problem, is they weren't as wide as the factory 'ears' on the rear -- and didn't fit snug like other shocks I've had. It might nto have made a difference, but I was worried about them sliding side-to-side and not working as well as they should have. So I put washers on either end of the bolt to keep them centered better.
Not huge, but enough that I did something about it.
zidane45
55
charleston,SC
Aug 13, 2004
#15
  • Aug 13, 2004
  • #15
check your pm stangGx
89MustangGX
Jul 3, 2001
10,262
Mill Creek, WA
Aug 13, 2004
#16
  • Aug 13, 2004
  • #16
PM'd back!
HISSIN50
34
129
Aug 14, 2004
#17
  • Aug 14, 2004
  • #17
ill toss one out from total left field. ive gotten struts for other cars which were retracted. i had to spin the strut piston to get them to extend (like you do with lotion bottles, liquid soap, etc).
just a long shot (since i have no idea about your struts - never used them). good luck.
89MustangGX
Jul 3, 2001
10,262
Mill Creek, WA
Aug 14, 2004
#18
  • Aug 14, 2004
  • #18
The STrange struts (mine at least) did not need to be spun out to extend. But you did make me think of something else when installing mine -- if they're set very tight they will be very hard to extend. If you set them to the lowest setting you should have no trouble pulling them out and pushing them in.
Hammer shifter problems
  • 387lx
  • Apr 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 11, 2026
General karthief
  • dan50
  • Jul 18, 2026
dan50
Most ridiculous / dishonest work you have heard a shop recommend?
  • SchwarzStock
  • Jul 19, 2026
  • Off-Topic Hangout
Off-Topic Hangout Jul 20, 2026
SchwarzStock
Suspension 87 steering wheel slightly wobbles after new Rag joint install
  • R82148V
  • Jun 16, 2025
Fox 5.0 Mustang Tech Jun 24, 2025
R82148V
Electrical 1985 mustang gt Led conversion trouble
  • 1985fox
  • Jan 5, 2026
Fox 5.0 Mustang Tech Jan 15, 2026
1985fox
