Strange timing issue
92 Bimini Blue
ontario
I have a '92 Fox and I'm currently dealing with a strange timing issue. I recently purchased a heads/cam/intake motor for my car and got it installed. For some reason, with the SPOUT connector out, the timing is advancing itself physically once the engine idles for about 15 to 20 minutes and is fully warmed up.
I have tried swapping out the TFI module, but that did not fix the problem. I reused my original Motorcraft distributor, which did not seem to have any issues on my stock motor. Could the PIP sensor be causing this strange issue? I don't want to just throw random parts at this thing in hopes of fixing it.
Considering the TSP plays a direct role in controlling the ignition timing advance, I would sort that and the IAC out before any continued tail chasing on the timing anomaly.
In order for a properly set base idle, you need a functional IAC. For proper timing control the base idle should be set and the associated TPS voltage needs to be within the correct range.
I know you’re thinking that because the condition happens when the spout is pulled, that means the throttle body issues are irrelevant. But do we “know” that? Perhaps the EEC is entering a base setting mode because it’s not getting the correct signals from the TPS, IAC etc….
Sort out and correct the TB and any other known issues before chasing the unknown cause of the timing advance.
Other than that, it’s possible the EEC thinks the spout is still installed due to a short in the spout circuit . When you pull the spout with the engine running, does the engine idle charge or do you notice a stumble? Normally you can see / hear a change when it’s removed. If you don’t, maybe there’s a wiring problem.
Reactions: DadLife0724
That definitely makes sense. I have been trying to set the IAC and the TPS in the correct range, but I do not get a lot of time before the timing starts extremely advancing itself to the point where I have to shut it down and let it cool off. Last night, while I was setting the idle after replacing the TFI in hopes it would fix the issue, the RPMs shot up and the car started to run badly. When I checked the timing mark, which was originally set at 12 degrees, the mark was pegged past 40, so I quickly shut it down. This is the first Fox I have ever owned, and also the first time swapping an engine. I apologize for my lack of knowledge; I kind of dove head first into this project. Also to add when removing or reconnecting the spout I do see and hear a change.
Talk a deep breath, exhale, clear your mind..
Disconnect the battery, set the idle screw so it just touches the arm for the throttle blades, check vac lines, kill 10-20 minutes reconnect the battery, set the TPS, turn key on, wait the two-three seconds fuel pump prime, start the car, get it warmed up, if you can drive it around block ok if not, feather the gas a little get it warm, do the base idle reset, don't worry about the timing, how does it run?
Check codes.
I thought he said with the SPOUT OUT it was doing it.... Should be dead locked like that....
Mark
That is what I thought as well. I haven't had a lot of time to work on it lately, but I'm going to do some more tinkering tomorrow. Yes, this is happening with the SPOUT out completely disconnected. I will report my findings once I get the TPS and idle set correctly.
Try a different light, make sure its only near the number 1 wire. No spout in there should be nothing controlling the timing, the coil fires directly off the pip signal. You can actually physically do that with no ecu even plugged in, it how ppl have used the tfi distributor on carb swaps. Either somethings messed up in the wiring, the distributor is walking advancing itself, or your lights picking up interference from another cylinder. Said its your First fox, your familiar with sbf 1234/5678 bank layout? Wouldn't be the first I've seen people try checking timing with the light on cylinder 5 because they where chevy guys.
Sorry for the late reply. I replaced the harmonic balancer with a brand new unit. There shouldn't be any interference, i am on the number 1 plug. The firing order is correct with no crossed wires. The ECU is stock with no chips or tunes.
I wouldn't say the issue is sporadic. After a 15 minute idle seems to be heat related, the timing steadily advances from 12 degrees all the way up to 40 degrees. I'm suspecting the PIP might be the problem? considering maybe just buying a whole new distributor with a TFI module at this point.
I concur. Don't see how it can be anything else, except for the theory some others mentioned. If for some reason there's still resistance on that circuit, the computer may be in control. One approach would be to view what's happening with a live data, like with a quarterhorse to see if it's actually commanding that timing. But start with a known good dizzy. I keep one on hand for this kind of thing.
