Street Sceenes Side Scoops
  • Thread starter Thread starter Casey4s
  • Start date Start date Oct 2, 2007
First Prev 2 of 2
Casey4s
147
Woodbridge, VA
Oct 10, 2007
#21
  • Oct 10, 2007
  • #21
dmaxstang said:
What did you do to alter the rear valance? I have been looking to add that valance on mine and was thinking of keeping it stock besides that. Do you feel it would look alright without the sides done from the same kit?
There were these flaps that were supposed to go up the back of the wheel well, that look fine if the car is same color but just didn't work for me in black.
I started trimming the excess away ...
Then after it was all trimmed off, i glued a piece in to fill some of the void...
Then I filled it with Bond O......
Sanded it down...
Placed it against the car and filled it again...
Sanded it again...
After all the final sanding, it was paintd matt black, and installed on the car...
backinblack68
#22
  • Oct 28, 2007
  • #22
Hi guys, I'm a little new to this , but I do know my tires. The reason there is such a gap btween his tires and wheel well , is because he has a smaller aspect ratio tire (lower profile. For example , stock 235/55 tires have a "height" ratio of 129 while 285/35 only have a ratio of 99.75. sure the 285's are much WIDER, but they are also smaller in height. Thus the gap
kooldawg6
mine works really well and can take a fair amount
Aug 31, 2006
1,679
Central VA
Oct 29, 2007
#23
  • Oct 29, 2007
  • #23
So this is how is car his lowered not once, but twice. Once with the lowering springs and then again due to the lower sidewall.
I went the opposite way. Stock suspension and grew 1.1" in rear tire height Fills up the rear fender pretty good.
blackonblack06
108
San Antonio, TEXAS
Oct 29, 2007
#24
  • Oct 29, 2007
  • #24
Beautiful ride ...it does look like a stock riding height though. I like that rear valence I have the same one but it is still in the paint shop along with my new hood. Can't wait to get it installed gonna be sweet!
It does look like a stock suspension ride height to me as well. With 18" rims and even a low profile tire should not be that much of a gap especially in the back. But then again who knows Different products may appear differently. Does it lean a lot when cornering?
blackonblack06
108
San Antonio, TEXAS
Oct 29, 2007
#25
  • Oct 29, 2007
  • #25
At the risk of going off topic...do you have problems with the tire scrubbing the fender wells? I love my Mustang but the stock suspension really is bad for flexing a lot.
stangdude2000
1,727
Northern VA
Oct 29, 2007
#26
  • Oct 29, 2007
  • #26
Its just the camera playing tricks on you. I've seen his car in person, and he's definitely got it dropped.
blackonblack06
108
San Antonio, TEXAS
Oct 29, 2007
#27
  • Oct 29, 2007
  • #27
Cool! What really matters though is his ride looks bad ass. Great job
Casey4s
147
Woodbridge, VA
Oct 29, 2007
#28
  • Oct 29, 2007
  • #28
The tires are 26" but I have no idea why it looks higher than it is, I had to get a new floor jack because the one I had would no longer slide under the car. It doesn't lean really at all, it corners like a go-cart. I am going to change the Shocks/struts and springs again this winter sometime. I am going with the Tokico D-specs with matching lowering springs.
kooldawg6
Aug 31, 2006
1,679
Central VA
Oct 30, 2007
#29
  • Oct 30, 2007
  • #29
:OT:
They have not rubbed at all.
kooldawg6
Aug 31, 2006
1,679
Central VA
Oct 30, 2007
#30
  • Oct 30, 2007
  • #30
When my car was on OEM tires, Casey's car was right next to mine and was noticeably lower.
First Prev 2 of 2
Engine pulling procedure on a 70 Mach I
  • Superdan
  • Jul 6, 2025
Classic Mustang Specific Tech Dec 26, 2025
Mach1 Driver
M
M
Rim suggestions
  • mason5.0
  • Sep 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Qtrhrse23
Need dimensions for hood scoop install
  • Mustang5L5
  • Sep 19, 2025
1996 - 2004 SN95 Mustang -General/Talk- Oct 15, 2025
Mustang5L5
J
Fox Lost all gauge cluster function after Holley Terminator X install (solved)
  • Justin17383
  • Nov 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 13, 2026
2000xp8
NFL is back on the menu, boys!
  • Ronin38
  • Sep 14, 2026
  • The Sports Bar
The Sports Bar Monday at 7:08 AM
Ronin38
