D.Hearne
331 stroker--- roller 5.0 block, Canfield heads ( 57 cc chambers 1.94 intakes/1.60 exhausts), Eagle cast steel crank, SIR rods, SRP pistons, Mustangs unlimited main girdle, modified Hamburger-fox body 7 qt oil pan ( to fit an 89 Rangers front axle) , Ford Z303 hyd roller with 1.7 Comp Cams roller rockers (.587 lift/228 degree duration @ .050) , Intake is a repro Ford 3x2 intake with 3 Holley 250 cfm carbs, Headers will be Shelby type Tri-Y's. Anyone want to make a guess on HP ? Transmission will be a wide ratio Toploader 4 speed, rear is 3.73 geared 8.8 W/Strange axles, trac-loc, and 275/60/15 radials
