Strong Stroker Combo
  • Thread starter Thread starter 93cobra12
  • Start date Start date Jan 7, 2004
9
93cobra12
531
Seatte, WA
Jan 7, 2004
  • Jan 7, 2004
looking to see if the 331 with the 185 AFR is a strong combo.. How much hp & tq would that combo give me at the wheels.. Is anyone running this combo? Are 331 powerful down low ?
TIMMY2734
1,330
Queens, NY
Jan 7, 2004
  • Jan 7, 2004
yeah, but it really depends on the cam that you will use. A stroker will give you more torque because of the extended stroke
9
93cobra12
531
Seatte, WA
Jan 7, 2004
  • Jan 7, 2004
how about an anderson b31 cam with a v2-sq trim.. will that help my low end out?
runningmole
1,127
San Diego, CA
Jan 7, 2004
  • Jan 7, 2004
You won't need to worry about low end w/ a stroker I'd personally get a cam from Ed Curtis (I did actually!) It's only a few $$$ more than those Anderson cams.
Rick 91GT
Mustang Master
95
99
PA
Jan 7, 2004
  • Jan 7, 2004
Personally if it is properly built you will make 500RWHP and be on the verge of breaking the block in half......
9
93cobra12
531
Seatte, WA
Jan 7, 2004
  • Jan 7, 2004
Rick this is professionaly built with a sportsman block w/ a girlde an all forged internals... I dont think i have to worry about splitting the block in half.. 500rwhp, not bad for a street car
9
93cobra12
531
Seatte, WA
Jan 7, 2004
  • Jan 7, 2004
i was hoping for 550 + personally.. What else do I need to do to get those numbers ?????
Combo so far:
TFS track heat intake
185 AFR heads
v2-sq stock pulley , anderson power pipe
b31 cam , 1.6rr , upgraded springs for valve float
BBk long tube headers , dr. gas 3'' x pipe ( off road ) , mac 2 1/2 cat back
kurban FR , 42lb injectors , 255 pump , vortech inline pump , bigger fuel rails
electric fan , fluidyne radiator , 180 stat
a/c delete , smog pump delete
aluminum driveshaft, aluminum flywheel , centerforce dual friction clutch , 373 gears
blah blah blah list goes on...
what else do i need to do to get to the 550+ mark ?
onefaststang
Kingpin
9,049
Elmira NY
Jan 7, 2004
  • Jan 7, 2004
I split a 351w (393 stroker)block down the middle with 600rwhp. Some guys last with 500, and some don't, it's a game of chance. You should honestly make 450+ to the ground with a good combo. The sportsman blocks aren't really much stronger than the factory production pieces. I've got a svo block now and it's a little beefier, but not much. Also, a girdle is only really going to keep the pieces together when it does split. A girdle wouldn't have helped my motor, it ripped the mains out all the way to the cam bearings. Girdle isn't going to help that much.
9
93cobra12
531
Seatte, WA
Jan 7, 2004
  • Jan 7, 2004
I forgot to add 331 set for 8.8 compression
Rick 91GT
Mustang Master
95
99
PA
Jan 7, 2004
#10
  • Jan 7, 2004
  • #10
Are the 185's stock or do they have the upgraded springs....crank the boost up and get your numbers.
9
93cobra12
531
Seatte, WA
Jan 7, 2004
#11
  • Jan 7, 2004
  • #11
OUCH !!! im sorry man.. was it N/A?
are you talking about my motor being N/A or with the power adder.. cuz i know theres no chance in hell i can make that much power from my combo without the power adder.. This is also a daily driver so i dont romp on it 24-7... Thats the main reason on why i bought a 331, for its long life ( supposably)
9
93cobra12
531
Seatte, WA
Jan 7, 2004
#12
  • Jan 7, 2004
  • #12
I do have the upgraded springs, How much boost could I run safely before denotation takes place?
Rick 91GT
Mustang Master
95
99
PA
Jan 7, 2004
#13
  • Jan 7, 2004
  • #13
JR's cars was a YS-Trimmed 393-396
I've been told the same thing that JR stated, although stronger the Sportsman blocks can still snap in half. Detonation is a killer......
I also dumped the pipe dream of a stock block or Sportsman block 351W and upgraded to a Ford Racing block.
Boost does not cause detonation, too much boost with a bad tune does. Just make sure your tune is good. What tuner are you going to run, your going to need one. I woulkd suggest getting the Renegade Pulley set-up with the brace that goes from the crank pulley to the blower to keep the stress off the front main, worth the money. www.rhodescustomauto.com e-mail Spence they make a modified version that is very nice, better then the Vortech design, tell him I sent you.
9
93cobra12
531
Seatte, WA
Jan 7, 2004
#14
  • Jan 7, 2004
  • #14
are you talking about a PMS or something like that? like a computer management system? I will check that webpage at, thanks.. Im tryin to have a show/go car, i got everything polished, chromed and cermachromed in my engine compartment, do they offer this brace polished or a form of polished/chrome?
M
  • Poll Poll
Stroking a Mexico 289 or newer roller 302
  • MaryJaneTheMustang
  • Aug 12, 2026
1965 - 1973 Classic Mustangs -General/Talk- Aug 12, 2026
Bullitt347
  • Locked
Engine Might have to get a Dart block but don't want to and if I do, then 363 instead of 331. Thoughts on what I've already bought so far.......
  • from6to8
  • Jul 8, 2025
Fox 5.0 Mustang Tech Jul 8, 2025
Need some camshaft guru advice on power loss from supercharger to nitrous
  • TTSaleen
  • Dec 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 29, 2025
revhead347
9
Milton Questions, 351 swap newedge
  • 996stang
  • Jul 20, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 25, 2026
Killer351w
K
Resolved Fixing a GT40P Valvetrain nightmare
  • foxbodyclark
  • May 21, 2025
Fox 5.0 Mustang Tech May 24, 2025
limp
