Strut rattle
  • Thread starter Thread starter JD1964
  • Start date Start date Apr 13, 2025
First Prev 2 of 2
JD1964
there is enough sticking out to grab on to
3,618
1,627
194
Maryland
Apr 15, 2025
#21
  • Apr 15, 2025
  • #21
Then I saw the hood was teetering on the latch meaning the latch was high compared to the rubber bumpers at each front corner. I lowered the latch so the hood now sits tight against the bumpers. I thought for sure I had found the culprit in this but after test driving……rattle still there
Admin Dude
Jan 4, 1985
43,535
21,704
234
Box behind Walmart
Apr 15, 2025
#22
  • Apr 15, 2025
  • #22
Damn.
I thought you had is for second...
JD1964
3,618
1,627
194
Maryland
Apr 15, 2025
#23
  • Apr 15, 2025
  • #23
Got up under it again. Checked motor mounts, k frame mounts, steering rack mounts. All are tight and show no signs of movement
JD1964
3,618
1,627
194
Maryland
Apr 18, 2025
#24
  • Apr 18, 2025
  • #24
I have a guy I’ve known for many years in my neighborhood. Depending on how you might assign titles, he’s a Foxbody expert among all other aspects of car enthusiasts and he works on them for a living. Although I do 99% of my own stuff, he’s who I bounce stuff off face to face when I need help.
He and I talked yesterday and I was planning to drop the car off to him to see if he could figure it out. After discussing it with him we’re 99.9% positive it’s the UPR plates and the spherical bearings that by design have practically no dampening feature.
So, it’s live with it or change to something different. What type of design is the MM? What kind of dampening is built in to them if any?
AeroCoupe
6,195
4,297
183
Claremore, OK
Apr 18, 2025
#25
  • Apr 18, 2025
  • #25
All I can say is the MM plates are the industry standard. I have zero issues with mine and have not heard or read of complaints on them.
What can caster-camber plates do for my Mustang?
Reactions: JD1964
manicmechanic007
5 Year Member
Sep 26, 2017
2,562
727
143
Roy, Utah
Apr 21, 2025
#26
  • Apr 21, 2025
  • #26
The aftermarket strut mount camber plate setup might be flexing and making noise at the interface with the strut tower
On Taurus, we had the same issue with the factory strut mounts
Ford came out with strut plates about 3 years too late
I had been fixing them with washers for years
Some were welded with not enough room in the tower area
You could try what I used to do
Lower the strut down with the mount
Add a washer to ech of the studs and put the strut back up in and re torque the nuts
See if that helps
Google Taurus strut plates and you may see one
Those plates (or using the washers) moved the strut mount down enough to not contact the tower
manicmechanic007
5 Year Member
Sep 26, 2017
2,562
727
143
Roy, Utah
Apr 21, 2025
#27
  • Apr 21, 2025
  • #27
What happens on Mustangs (and Taurus)
When you move the strut to correct the camber and caster, you run the risk of the plate contacting the tower at the outside edges
When the mount flexes, you get the pop
Lowering the adjustable strut mount 1/8 inch down and away from the tower helps
JD1964
3,618
1,627
194
Maryland
Apr 21, 2025
#28
  • Apr 21, 2025
  • #28
I understand what you are saying. Next time im up under there, ill have another look
manicmechanic007
5 Year Member
Sep 26, 2017
2,562
727
143
Roy, Utah
Apr 22, 2025
#29
  • Apr 22, 2025
  • #29
Usually, you can't see much until you pull the strut out 2 years later, and then you might be able see witness marks around the edge of the plates
Reactions: JD1964
First Prev 2 of 2
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
J
Severe shaking/vibrations in steering wheel
  • jacket999
  • May 20, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jun 1, 2025
NtheGAME
N
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
Eight inches is enough for me...
  • 351MooseStang
  • Nov 27, 2025
1974 - 1978 Mustang II Talk & Tech Mar 2, 2026
Bullitt347
Progress Thread "Alter Ego" White 1993 LX 5.0 5spd
  • idareu
  • Sep 9, 2024
  • 2 3
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 19, 2025
idareu
