I am replacing all the springs/struts on my fox body. Did the rears real quick, moved on to the front.
Here is where I am stuck. I just can not get the nut off the top of the strut. I tried putting a huge flathead in from the side into the notch and holding it while I turned it...no luck. Tried using heavy duty air gun, no luck. The rod just spins inside the strut.
Any ideas? I guess worse case scenario I have to buy a new strut guide?
Thanks.
Thanks.
