  • SN95 4.6L Mustang Tech
struts or shocks 01 GT
  • Thread starter Thread starter dtstang
  • Start date Start date Mar 3, 2008
D
dtstang
  • Mar 3, 2008
I have a 01 GT Conv. When driving the car i hear a squeeking noise coming from the front right fender well. It happens going over all bumps and some extreme uneven roads. Its kind of a rough ride now as well. I'm thinking its either the shocks or struts. The car only has 50,000 miles on it but it is 7 yrs old.
Wondering if anyone has ever had this problem before and what they did to fix it?
joshjwc9
1,095
17
39
Palm Harbor, FL
Mar 3, 2008
  • Mar 3, 2008
It could be the old struts on the front, the shocks are in the back.
It could be a tie rod, I have the same problem except I cut a little slit in the tie rod boot and spray WD40 in there.
joshheat25
871
Delaware
Mar 3, 2008
  • Mar 3, 2008
Do not cut a slit in the tie rod boot! the tie rod boot is meant to hold grease and there is a fitting on the bottom of the tie rod in which you use a Grease Gun and put grease in there. It could be your struts. I know mine are shot.
D
dtstang
  • Mar 3, 2008
Didn't know that there weren't any shocks in the front thats definately helpful. The noise is only coming from the front. Is there any way to tell what the problem is before replacing the struts and seeing if that works. I've always thought that if you replace anything in the front like struts that its best to do it all around?
You know my second, or third or forth question is going to be: What struts are you guys going to get? I'm looking for something a little better than stock but not that expensive.
Thanks for the info
40th GT
916
Lawrenceville, GA
Mar 3, 2008
  • Mar 3, 2008
I don't think the struts/shocks are making that noise. I'd start out by changing your bushings in the front, because I'm pretty sure they're shot considering the mileage of your car.
01 GT DRIVERS SIDE DOOR LOCK CYLINDER LINKAGE
  • Scwhitten
  • May 13, 2026
SN95 4.6L Mustang Tech Jun 19, 2026
melo.timo
M
Drivetrain Rear end clunk
  • seanmahoney
  • Oct 13, 2025
SN95 4.6L Mustang Tech Oct 13, 2025
nickyb
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
Suspension Rear driver side sits lower than rear passenger side...?
  • 91GTstroked
  • May 15, 2024
3K
Fox 5.0 Mustang Tech May 18, 2024
91GTstroked
