struts
I used 99 a arms, 94/95 spindles an fox struts. From what I've read, The sn95 struts are longer. They are partially compressed at normal ride height, which makes the ride harsh. They also bottom out easier. I had 02 take offs on an 87 an it rode rough.
I put them on an 84 which is .5" narrower per side than the 87 up foxes. the rim sits just barely inside the fender lip. I'm using 225 wide tires up front an it still looks a tad wide. I may go with the 05 wheels to get more off set an move the width in a little.
The 05 wheels will help. They have a +45mm offset, bringing them in 15mm over the stock 94-04 17X8's.
