stumbling when in gear
Stumbling in gear can be a few different things.. could be spark, check while running, in gear after dark with the hood open. One person in car holding break and applying a little gas, the other looking under the hood for jumping sparks. If not, then check your vacumn hoses and fittings. You can spray carb cleaner around questionable hoses and fittings. If neither of these is the culprit, then I would look to the carb.
