95 escort/auto+air. compression-170,150,155,170.--computer shows no codes--spark plugs looked identicle and good(a little dry)--motor has 140,000 on it--cured all vacuum leaks--new plug wires and plugs--gutted the cat(merely precautionary)--symptom, it gradually lost power over the last 1500 miles , now not running smooth enough for road use.///// Dumb question zone.... do you roll the motor up toward the driver's side to do a timiing belt?-- to remove the timing cover, do I disassemble the belt tensioner or remove the accesory bracket it's mounted on. Fuel pressure or supply has not been verified yet.--it sounds like a vw for a few weeks now. Any suggestions?
