  • 2.3L (N/A & Turbo) Tech
Stupid flasher.. ****!
  • Thread starter Thread starter Keasbey
  • Start date Start date Jul 12, 2005
Keasbey
915
Montreal
Jul 12, 2005
  • Jul 12, 2005
The flasher don't flash anymore.. it simply stays on.. And I can't found the relay? where is it?
thanks
J
JB66
565
New York
Jul 12, 2005
  • Jul 12, 2005
If it stays on, it's probably a bulb. The turn flasher is probably under the center of the dash in one of 12 locations...
Shawneebear93
20+ Year Stangneter
May 4, 2004
518
17
49
Salisbury Twp, Allentown, PA
Jul 13, 2005
  • Jul 13, 2005
The flasher fuse is under the passenger side dash.
stangs4evr-roy
57
  • Jul 23, 2005
like jb66 says it sounds like a bulb so check them first.
Keasbey
915
Montreal
Jul 23, 2005
  • Jul 23, 2005
yeah but it only happens when the temperature(not the car temperature, but the outside temperature) is very high..??
J
Jacob07
96
Missouri
Jul 23, 2005
  • Jul 23, 2005
The switch that makes them flash works by heating a piece of metal but I think it would have to be extremely hot to mess that process up. I think you can get another for maybe $5. (Its the larger metal thing in your fuse panel)
Keasbey
915
Montreal
Jul 24, 2005
  • Jul 24, 2005
ok so I will check all that tomorrow
If the bulbs were "damaged", the flashers should flash faster? no?
I will frist replace the thing in the fusebox
J
JB66
565
New York
Jul 24, 2005
  • Jul 24, 2005
The flasher in the fuse box is for the hazard flashers. The one for the signals is the one under the dash. When a lamp filament is broken, the good lamp stays on steady.
Keasbey
915
Montreal
Jul 25, 2005
  • Jul 25, 2005
Okay, but if both side is doing it at the same moment?
Do this relay is on the driver's side, or passenger's side? or in the middle? I've searched in my haynes manual, but there is nothing about the flasher relay..
J
JB66
565
New York
Jul 25, 2005
#10
  • Jul 25, 2005
  • #10
try under the radio or next to the glove box.
Keasbey
915
Montreal
Jul 26, 2005
#11
  • Jul 26, 2005
  • #11
Problem solve!
This flasher relay is behind the fuse box
140CILX-Coupe
189
#12
  • Jul 26, 2005
  • #12
if the outside marker light is missing will the inside marker light not light up?
J
JB66
565
New York
Jul 26, 2005
#13
  • Jul 26, 2005
  • #13
Nice find!
Keasbey
915
Montreal
Jul 27, 2005
#14
  • Jul 27, 2005
  • #14
Have not look for this one tho... but I don't think so..
T
Need help 67 hazard flashers not working
  • THS70
  • Jan 21, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jan 29, 2026
Fox Turn signal flasher keeps failing
  • keel
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 9, 2026
A
1966 Mustang coupe / Brake lights and left rear turn signal not working.
  • ArizonaRob1966
  • Nov 3, 2025
Classic Mustang Specific Tech Dec 24, 2025
Mcmahst
Fox won't crank over and fuel pump won't kick on.
  • djj62478
  • Jun 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2026
General karthief
D
Turn signals work only with ignition on & Engine off.
  • DienstXIV
  • Jul 2, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 7, 2025
DienstXIV
D
