Turn signals work only with ignition on & Engine off.
Hey everyone, I have a 1985 Mustang GT that is currently my daily driver. Driving to work this morning, my turn signals quit working, no lights on dash, no lights on exterior, no ticking. I changed out the flasher and noticed that when the ignition is on but the engine is off, the turn signals work but when I turn the engine on, they stop working. Hazards work fine either way.
Anyone have this issue and known where I should look to fix it?
Any advice is much appreciated
Cheers,
Alex
Some simple probing with a test light will tell you if the current one is okay with it being g replaced in the last 5 years I’d assume it’s good.
My next guess would be the multifunction switch a.k.a. The turn signal switch.
Reactions: DienstXIV
It’s the turn signal switch which is in the steering column. It’s called a multifunction switch as it does turn signals, hi/lo beam, and the hazards.
This is for an 86 so similar:
You should invest into one of these:
I have this type of wiring diagrams for both of my cars and they have saved my butt several times:
