  • 1994 - 1995 Specific Tech
Stupid Question..misfire?
  • Thread starter Thread starter FlyBy763
  • Start date Start date Sep 18, 2007
FlyBy763
439
Palm Bay, FL
Sep 18, 2007
  • Sep 18, 2007
The past month or so my car has been missing bad up top, after like 4500 RPM. I changed my plug wires and checked the belt tension on my blower belt...my question is: Is it possible I am mistaking my clutch slipping up top only for a miss? Have any of you had a clutch only slip at the top of the tach, what it feel like? I still have to look at the plugs to see what they look like, cap and rotor are new also.
toyman
1,944
54
79
Vernon BC
Sep 18, 2007
  • Sep 18, 2007
A slipping clutch would be obvious. RPM's would increase without a corresponding increase in speed. Missing is like a loss in power and has a unique feel to it. No codes being thrown? Could be fuel or electrical related. Depending on when the plugs were last changed I would check them and then fuel pressure although if that was an issue I think you would have a lean condition and hear a knock. I'm betting it's electrical.
Stanger007
2,015
Baton Rouge, LA
Sep 19, 2007
  • Sep 19, 2007
Spark blowout?
What are your plugs gapped at? Got a picture of a plug we can look at?
I have mine gapped at 0.028 on stock distributor/TFI, MSD coil and Taylor wires - it pulls up to 6,000rpm where I have it shifting. Using Autolite 24's here.
Wes
FlyBy763
439
Palm Bay, FL
Sep 19, 2007
  • Sep 19, 2007
Stanger007 said:
Spark blowout?
Wes
.032...NGK plugs, cross to an autolite 24. TR6 I think.
Ill pull a plug tonight and look at it.
FlyBy763
439
Palm Bay, FL
Sep 19, 2007
  • Sep 19, 2007
Plugs look fine to me. We can add backfiring to the list now...
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
M
Help! 2003 GT misfire when hot
  • Modular03
  • Feb 10, 2026
SN95 4.6L Mustang Tech Feb 13, 2026
Mustang5L5
Engine Hiccup at full throttle
  • keel
  • Jun 2, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
keel
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
Engine Misfire below 3K RPM
  • foxbodyclark
  • May 25, 2025
Fox 5.0 Mustang Tech May 31, 2025
General karthief
