Sub frame install....
  • Thread starter Thread starter TC93
  • Start date Start date Jan 26, 2007
TC93
Well-Known Member
Sep 11, 2000
2,075
Ellerslie GA 31807
Jan 26, 2007
  • Jan 26, 2007
I know the suspension should be loaded when intsalling sub-frames. But should the motor & tranny be in the car also?? I have a little ways to go before my motor & tranny will be ready to drop in, and was thinkign about welding my sub's in.
D
DRock9
359
  • Jan 26, 2007
I would think that it would be better to have everything installed as if it was running, but I am not sure so don't go with my word. I would use the logic that the car won't be running until it has a motor so why do SFC's now? It won't run before it has the motor in it.
JChalfan
551
Bellevue, WA
Jan 26, 2007
  • Jan 26, 2007
I would definitely wait until the engine and trans are installed, so the car sits like it should when you weld in the subframes.
TC93
Well-Known Member
Sep 11, 2000
2,075
Ellerslie GA 31807
Jan 26, 2007
  • Jan 26, 2007
Was thinking of putting them in now while doing the body work and all. I plan on having the car painted before I install the motor/tranny. Oh well though, guess I will wait until the motor and tranny are dropped in..
nonglossjason
I did not have intercourse with a sheep.
Jan 27, 2006
138
20
39
Jan 26, 2007
  • Jan 26, 2007
well you should put the motor in anyway before painting so you dont scratch it putting it in
87GTSnake
96
PA
Jan 26, 2007
  • Jan 26, 2007
Not if he wants to paint the engine bay at the same time.
TC93
Well-Known Member
Sep 11, 2000
2,075
Ellerslie GA 31807
Jan 26, 2007
  • Jan 26, 2007
Exactly what I am doing. Only thing that will be in the car when its painted is the front & rear glass,, nothing else.
Fett
766
  • Jan 26, 2007
Wait until after paint to install the subframe connectors. You want your car sitting exactly how it will run. With no engine or trans, the front suspension will be extended.
Technically there might be nothing wrong with doing it that way, I know people who installed SFCs with the car on jack stands and the tires hanging in the air....but that is not the correct way to do it.
If I were you, I would paint the car, finish putting it back together, get it running and aligned, THEN put the SFCs on.
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Jan 27, 2007
  • Jan 27, 2007
place some weight in the engine bay.....
BlooDReigN
283
Calgary, Alberta
Jan 27, 2007
#10
  • Jan 27, 2007
  • #10
Yeah...just get a bunch of buddies to stand/sit in the engine bay and sip back a few beers while you are welding
M
Electrical 93 5.0 No Injector Pulse
  • machinermac
  • Jul 26, 2026
Fox 5.0 Mustang Tech Aug 1, 2026
Willybill32
K
Engine Gt40p vs 180 procomp
  • Kleinjj27
  • Oct 27, 2026
Fox 5.0 Mustang Tech Nov 3, 2026
Kleinjj27
K
Strange timing issue
  • 92 Bimini Blue
  • Sep 26, 2026
Fox 5.0 Mustang Tech Oct 20, 2026
rednotch
W
Electrical 91 GT Alternator Replacement Question
  • willrh111
  • Oct 22, 2025
Fox 5.0 Mustang Tech Oct 23, 2025
nickyb
Suspension End link replacement size
  • Teen'93stang5.0
  • May 12, 2026
Fox 5.0 Mustang Tech May 20, 2026
Teen'93stang5.0
