SUBFRAME CONNECTOR PROBLEM
  • Thread starter Thread starter Nemesis67
  • Start date Start date Jul 15, 2006
N
Nemesis67
146
Las Vegas, NV
Jul 15, 2006
  • Jul 15, 2006
I got Total Control Products subframe connectors and I've run into a problem. The drivers side fits like a glove but the passenger side is another story. When I put the front cup onto the front floor support the rear part that welds to the rear torque box/frame rail it sits too low. About an inch and a half. The tech support guy at TCP told me that I should attach the front and then force the rear into place. In other words bend the crap out of the floor support and floor. Anyone else had this problem? I thought about welding the rear in place first. The front still makes more than enough contact. It's just that I have about a 1/8 inch gap between the front floor support and the bottom cup area of the subframe connector. Then I could weld a 1/8" piece of flat steel in the gap to take up the space and make it stronger in that area. Anyone have a better Idea?
Cannoball888
320
Gainesville, FL
Jul 15, 2006
  • Jul 15, 2006
I've read that most if not all weld-in subrame connectors require floor pan mods. This is why a lot of people get the bolt-on ones and then weld them on. I don't know why the bolt-on ones clear the floor pans, but apparently they do. You might consider returning them if you haven't welded them in yet.
dodgestang
1,360
Cecil County, MD
Jul 15, 2006
  • Jul 15, 2006
I would tack the front, then apply a floor jack the rear and crank till it goes into place. It sounds like you are fighting a body that has been 'tweaked' at some point in its life.
P
PJx5x
197
Chicago
Jul 16, 2006
  • Jul 16, 2006
are you using a lift? drive-on?
66Runt
680
Jul 16, 2006
  • Jul 16, 2006
I think Dodgestang and PJx5x nailed it
Just for grins to double check the subframes put them next to each other. They should be perfect mirror images of each other.
Mine fit incredibly well.
mdjay
Premium Sponsor
Dec 9, 2003
896
Las Vegas, NV
Jul 16, 2006
  • Jul 16, 2006
Most of these cars are bent to some degree and most will run into similar problems.
68FBJJZ109
357
Easton, PA
Jul 16, 2006
  • Jul 16, 2006
I had the same problem. The sub frames touvh my floors, and when i would get one side inplace it would cause the other side to come loose, like a see saw. I tried pushing in the flores as much as i could though it didnt really help. I was replaceing th floors any how. The old floors apparently sagged much more then I thought. There fore i cut them out,they went almost right in. I had to put a dencet sized tack weld on the front then jack the back part with the X brace in place. You prob will have to hit the rear part into place with a rubbermallet and let the SF settle. Because at first when i jacked up the SF the whole rear of the car lifted up. After that i tacked the back. The welded them into place. thought there where slight gaps approxz 1/8 in gaps on the front where the SF cup the Frame rails. that can be filled with a bead. You should be fine There is alot of surface area on those SF to weld once there sit right.
M
mustangdave
My rearend needs a stud and two nuts.
2,976
North Carolina
Jul 16, 2006
  • Jul 16, 2006
68FB; have you ever thought about taking some English classes?<a href="http://www.smileycentral.com/?partner=ZSzeb008_ZNxdm117AAUS" target="_blank"><img src="http://smileys.smileycentral.com/cat/36/36_1_12.gif" alt="Wink" border="0"></a>
Fox Another try for the European guy to get his first Fox
  • Schargedfox
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 4, 2026
DadLife0724
How to Route Subframe-Style Intermediate Brake Line?
  • cnorman31
  • Nov 29, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 29, 2025
cnorman31
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
D
For Sale 1993 Mustang LX for parts or restore
  • diesel farmer
  • Oct 6, 2026
Fox Body Mustangs For Sale (1979-93) Oct 6, 2026
diesel farmer
D
4.6 spitting o-rings out of 2 injectors
  • skidad
  • Sep 30, 2026
  • 2 3 4
2K
1996 - 2004 SN95 Mustang -General/Talk- Wednesday at 1:55 PM
skidad
