Hi,
I need some help with some subs that I plan on getting. I plan on getting subs but I don't know which one's the best. I've narrowed it down to these three(Each sub will cost the same for me so price isn't a factor):
Apline Sub
MB Quart #1
MB Quart #2
Also the guy at the store told me that I'm going to need this
Amp but it's kinda out of my price range. Is there a cheaper amp that would be able to power 2 subs from the three that I listed?
Thanks!
Max
Apline Sub
MB Quart #1
MB Quart #2
Thanks!
Max
Depends on what you want. If you want some good sound go with 2 subs. A 5-600 watt amp would be fine. Unless you are trying to go competitive. 2 subs with that size amp sounds real good in a stang. Thats what I have. I do all my own work and it is real simple to do. If you have an aftermarket radio all it is is 3 wires and a set of RCA cables. Constant power fro battery remote wire from power antena wire on radio, ground wire and rca cables to radio. Its that simple
