subtle changes for more speed
  • Thread starter Thread starter greystang90
  • Start date Start date Aug 7, 2007
G
greystang90
Within 150 miles of Chicago
Aug 7, 2007
  • Aug 7, 2007
What can i do to make my car a little faster without spending a ton of time and money? An exhaust or exhaust manifold, a computer (probably expensive). My car is stock now but I want it to be a little quicker, can anyone help?
BK_CAULEY
it's built for speed not longevity, woman
Dec 26, 2006
49
Thomasville, ga
Aug 7, 2007
  • Aug 7, 2007
http://forums.stangnet.com/showthread.php?t=636360&showpost#3
85_SS_302_Coupe
6,945
1,598
223
Northern KY
Aug 7, 2007
  • Aug 7, 2007
Do all the little tuning tricks and then look at ways to reduce weight. The lighter you make the car, the easier the engine can make it move.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Aug 7, 2007
  • Aug 7, 2007
On a budget? do the junkyard upgrade...
Gears - 87-88 T-Bird Turbo Coupe rear axle - disc brakes and 3.55 or 3.73 gears in one package for $125-$300. Add another $100-$200 or so to complete the brake upgrade.
94-95 Mustang GT MAF - $40-$100. It is 70 MM instead of the stock 55 MM on regular stangs built prior to 94. It uses a slip on duct on the side that goes to the throttle body and a 4 bolt flange on the other. You need a flange adapter to fit the stock slip on air ducting that goes to the air box. Wiring plugs right in with no changes. *1 *2
95-97 Ford Explorer intake manifold & throttle body $150-$300. The intake manifold flows 220 CFM +, much better than stock. Throttle body is 65 MM, bigger than the 60 MM on stock stangs. I got a 96 with EGR passages that match the stock setup, so my smog gear works just like factory. You’ll need a 65 MM EGR spacer & new gaskets for $65-$90 so you have a place to mount the EGR & throttle linkage.
3G alternator from 94-95 Mustangs or other Ford. $20-$120. A must have to make the electrical system work like it should. You’ll need a 4 gauge power wire and a 125-135 amp fuse to go with it about $15- $30.
Lincoln MK VIII electric fan -$40-$160. Free up some HP by not having to drive the stock fan. The 3G alternator upgrade is a must have prerequisite before you do the MK VIII fan. You won’t have enough electrical power if you don’t do the 3G upgrade.
Aluminum driveshaft: (courtesy of shawn13) It needs to be from a 92-93-94 Aerostar AWD and you will need the u-joint, part #353 from NAPA. It should bolt right up after the u-joint swap.
*1.) A metal flange adapter is available from: http://www.kustomz.com/cat3.html . Buy the TR70 for $44.95.
*2.) MAF & sensor interchange
The 94-95 Mustang 5.0 MAF & sensor is also found on:
1995-94 Mustang 3.8L F2VF-12B579-A2A,
1994-92 Crown Victoria 4.6L F2VF-12B579-A2A,
1995-94 Mustang, Mustang Cobra 5.0L F2VF-12B579-A2A,
1994-92 Town Car 4.6L F2VF-12B579-A2A,
1994-92 Grand Marquis 4.6L F2VF-12B579-A2A,
The A2A, AA, AB, etc, on the end of the part number are minor changes that do not affect the calibration.
HISSIN50
34
129
Aug 7, 2007
  • Aug 7, 2007
FWIW, if you're pretty stock, the stock headers are fine.
The computer has nothing to do with performance. Tuning it can yield results after a large modification (forced induction, HCI, etc). I would not bother with anything till then.
Gears will be your biggest bang for the buck.
Good luck.
85_SS_302_Coupe
6,945
1,598
223
Northern KY
Aug 7, 2007
  • Aug 7, 2007
You could always throw a 75 shot of nitrous on it
That's a pretty safe amount of spray to run as long as your tune is good.
SVT32VDOHC
waiting for the next hack atta
3,501
28
119
Motor City
Aug 8, 2007
  • Aug 8, 2007
5spd?? 3.73 gears!!! A tune up really did a number on my notchback. I have no more hesitation and I can now burn tires in 2nd gear.....could not do that at all before. I spent 52 dollars on Motorcraft plugs, cap and rotor. I spent 39 bucks on Ford motorsport 9mm blue wires. I spent 30 minutes changing them for a noticeable difference.
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
E
4.6l auto to 5.4l 6 speed
  • EastanF5
  • Jan 22, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jan 22, 2026
EastanF5
E
Tunerstudio help / services
  • Kabuki_notch
  • Apr 26, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum May 2, 2026
Mustang5L5
