Summit Gears?
  • Thread starter Thread starter Darrin
  • Start date Start date Dec 24, 2007
Darrin
184
Cocoa, Florida
Dec 24, 2007
  • Dec 24, 2007
Has any one used the summit gears? I have to rebuild my rear in the car and I have to shave all prices that I can. I need axles, 3.73 gears, bearing kit. I thought about the summit gears but, I don't know anyone that has used them. I'd do the e-bay thing but, a$$H%@$# that list on there take a week just to box and ship the parts. At least Summit will have my parts to me in 2 days. (after Christmas of course)
91 HATCH
Banned
May 17, 2007
262
illinois
Dec 24, 2007
  • Dec 24, 2007
i would use them gears are gears get 3.73 5sp or 4.10 auto
jake2582
107
tallapoosa
Dec 24, 2007
  • Dec 24, 2007
i have figured out that most stuff that summit sells as their brand is really made by someone else.
there fuel pumps are walbro. (found that out yesterday)
Maryland Stang
1,656
30
39
Greenville, NC
Dec 25, 2007
  • Dec 25, 2007
It's far easier (and probably cheaper) to install FMS gears. By using a non-Ford part the entire rearend must be re-setup. In using the Ford parts you simply measure the 2 pinions heads to assure they're the same size and then adjust the shims to make them match if they're not. Reinstall the new pinion, set the backlash and you're ready to go.
If you do decide to go the non-Ford route then this tool will help with the setup....
http://www.ratechmfg.com/pinion setting tool.htm
9
91notchbk
163
Jackson Michigan
Dec 25, 2007
  • Dec 25, 2007
Summit gear-sets will work just fine. As somebody mentioned they are not manufactered by Summit and if I recall I think they are a Motive set. Anyways, I have used Ricmond, Motive, and FMS. They are all fine. Richmond does make a pro gear for heavy duty racing and hard launching that is made of a softer alloy to avoid breakage.
Setting the ring and pinion up does take some experience. I have set-up over 100 sets so I now have a eye for it. I will give you a few tips that I have learned over the years. Use these tips along with the complete procedure of installing a new gear-set.
-Start by removing the old large pinion bearing from the pinion gear and get the shim that is under the bearing. I always use the old pinion shim as a starting point for pinion depth.
-Put the old shim on the new pinion gear. I have a large pinion bearing that is machined to be a slip fit on the pinion gear and I use it to start. I simply slip it on the new pinion gear with the old shim underneath.
-I then install the the pinion gear in the housing without the crush sleeve and I tighten it down so I have no lash and a little bit of preload. *You don't install the crush sleeve yet because you may have to remove the pinion gear to change pinion depth later.
-I next use the old carrier shims and install the differential with the new ring gear attached. I make sure I tighten the carrier straps on both sides because if I don't my backlash may not be accurate. I measure backlash with a dial indicator. Typically I shoot for .010 +/- .002.
-Run a pattern with gear marking compound. This step is the KEY to success. Let me say this again this step is KEY to success. This will indicate exactly how the ring gear is meshing with the pinion gear.
-Brush the compound on the gear teeth to cover 4-5 gear teeth and cover the teeth completely on both the drive and coast side of the ring gear. Make sure you get a nice even amount of compound on the teeth.
-Have a friend help you create resistance on the ring gear by using a rag on his palm to hold the ring gear as hard as he can while you turn the pinion. Pass through the painted gears then revese directions and have your friend hold resistance in both directions so that you get a good pattern on both the drive and coast side of the gear. Turn the pinion gear smooth and steady to get a good pattern.
-Resistance is important for an indicative pattern. It may take a few tries to get a good pattern if you are new to this method. The pattern is key to sucess because depending on how the pattern looks will tell you if your pinion depth is correct and if your backlash is correct. If the pattern indicates changes in pinion depth then change the shim in .005 incriments. About 80% of the time the original shim will get your pinion depth perfect.
-When you are satisified with the pattern then remove the pinion gear and press on a new large pinion bearing and install your crush sleeve to set your pinion bearing preload. I use a solid spacer instead of a crush sleeve because it will never collapse like a crush sleeve may and it only costs $10. A crush sleeve is fine on most cars.
In summary: Setting up a gear-set is trial and error process. Remember, use the old pinion shim. Use a slip on large bearing if possible. Run a pattern with resistance and read the pattern. Adjust as necessary until a good pattern is achieved.
I have used the pinion depth tools but they just collect dust. I have found that they will get you close but are not always accurate. The shim method works for me and is about 80%. Remember this process is trial and error so be patient and don't run the car until you have a good pattern.
jake2582
107
tallapoosa
Dec 25, 2007
  • Dec 25, 2007
91notch. you are the 2nd person that has mentioned to me that they "slip" the rear pinion bearing on. i am going to try this next one i do. sounds like a great idea.
9
91notchbk
163
Jackson Michigan
Dec 25, 2007
  • Dec 25, 2007
Yep.
Darrin
184
Cocoa, Florida
Dec 25, 2007
  • Dec 25, 2007
Thanx... That will help a lot.
PUNISHER RACING
1,124
FORD CITY, PA.
Dec 26, 2007
  • Dec 26, 2007
my dd has Summit 4.30's they ain't dead yet
SublimeRT
230
Clarksville, TN
Dec 27, 2007
#10
  • Dec 27, 2007
  • #10
I was just looking at 4.10s for my car on Summit.....nice to hear that they're reputable. I actually Googled Summit Gear Sets and this was the first page it gave me, ha.
M
mavmavv
185
#11
  • Dec 27, 2007
  • #11
Wow! Thanks for those tips! I need to put 3.73s in my bucket, if I attempt it myself Ill definitely use this list.
Killer50stang
632
#12
  • Dec 27, 2007
  • #12
Point said...summit doesn't make the part, they buy it somewhere else and put their name on it. Just like Advance doesn't make oil, but they have oil with their name on it. I'd get Richmond Gears.
9
91notchbk
163
Jackson Michigan
Dec 28, 2007
#13
  • Dec 28, 2007
  • #13
I get my oil for my daily drivers at Auto Value. It is the Partsmaster brand and it cost around $1.50 a quart. It is much cheaper than the name brands. But it is actually Valvoline. It says right on the back "manufactered by Ashland oil company". Ashland oil makes Valvoline. There Partsmaster oil filters are made by Wix. This is true of gearsets, oils, and many other auto parts.
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
D
For Sale 1993 Mustang LX for parts or restore
  • diesel farmer
  • Oct 6, 2026
Fox Body Mustangs For Sale (1979-93) Oct 6, 2026
diesel farmer
D
Drivetrain 8.8 trac lok spider gears..
  • rednotch
  • Oct 28, 2025
Fox 5.0 Mustang Tech Oct 28, 2025
rednotch
D
What's it Worth? 2006 Mustang GT Convertable
  • doc0075579
  • Mar 2, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? Mar 2, 2026
doc0075579
D
